I have Rattle!
Old Nov 7, 2002
chicohonda02's Avatar
Since 2002 Baby!
I have Rattle!
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
I have rattling in my trunk. It's located by the third brake light up by the back window. The panel is apparently loose. What do you guys recommend I do? Will stuffing Dynamat inside the gaps do anything for me? Since we are civic owners I figured you would be best to answer a question like this. Plus in a trunk do you guys find that a bandpass box works better than a sealed? Or what works best. I have a sealed box but maybe looking towards changing??
Thanks
Chicohonda02
Old Nov 7, 2002
andyman97's Avatar
Turbo Guru
I still have trunk rattles, your best bet is to dynamat the entire trunk, then underneath your interior panels and go from there. Also make sure that you tighten everything before you dynamat it. As for your box, it really depends on what type of sub you have. If you have kicker comp vr's, they only recommend sealed boxes, so putting them in a bandpass box isn't going to sound as good as if you put them in a sealed box...you gotta be a little more specific.
Old Nov 7, 2002
LudlamTheory's Avatar
i boogie for the raindrops
sealed, ported, bandpass...... it all depends on what YOU want it to sound like.... what do you listen to... what kinda subs do you have... etc.etc.
Old Nov 7, 2002
fonto's Avatar
The LA Clipper
If you look at your back dash from the trunk you will see a black box. This I believe houses the middle seatbelt. I think that that may have potential for rattle.
Old Nov 8, 2002
Since 2002 Baby!
I have a single 12inch JBL GT1200 sub in a sealed box. I had it in a bandpass when I bought it. That sounded great, but in a different car. Its not very powerful, but loud. It does the job until I can get a pair of JL Audio's. The ****. If there is anything else you need let me know. I may pick up a JL audio 12w0, if this guy gives me a good deal. What type of box then, do you guys think? Just curious.
Thanks everyone for your help,
Chicohonda02
Old Nov 8, 2002
4Saris's Avatar
4Saris is an unknown quantity at this point
I had the same problem as well, but searched on this forum and found the answer. Someone came up with the ingenious idea to stuff eggcrate foam between the metal frame and plastic panel from the trunk. No more rattle.
Old Nov 9, 2002
cdmx's Avatar
Quote
[hr]Originally posted by: Chicohonda02
Chicohonda02[hr]
Get a 12w3
Old Nov 9, 2002
LiKEaFeRiO's Avatar
I also have rattling coming from my trunk!!!
There is a air passage behind the bumper in the rear drivers side. Im guessing it gives the trunk ventilation because when I turn up the volume the flap covering the air hole goes flalalalalalalalap~!!
How would you guys recommend I stop that?
Old Nov 29, 2002
KeNsHiN's Avatar
LEVA
we have too find some way of killing the lock noice!
Old Nov 29, 2002
beamer's Avatar
beamer is an unknown quantity at this point
take it to honda make them fix the d*mn thing
Old Dec 2, 2002
civicdude's Avatar
I had the same problem. I went to Home Depot and bought some airconditioning insulation. It is a long foam tube that I cut and stuffed between the deck and the rear window. I no longer have any rattlings.
Old Dec 2, 2002
andyman97's Avatar
Turbo Guru
Quote
[hr]Originally posted by: civicdude
I had the same problem. I went to Home Depot and bought some airconditioning insulation. It is a long foam tube that I cut and stuffed between the deck and the rear window. I no longer have any rattlings.[hr]
How does it look, where did you fit it in? Do you have any pics of it?
mistahlorax13
21
Nov 18, 2015 12:47 PM
rovafa2002
Sep 28, 2015 06:57 PM
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
Yazan93
Jul 14, 2015 08:56 PM
