porting an enclosure
Old Oct 28, 2002
LudlamTheory's Avatar
i boogie for the raindrops
when porting an enclosure, lets say i wanted super long ports, i could also run ports outside the box too, right?
Old Oct 28, 2002
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
uhh I guess so i don't know why you'd want to run them outside the enclosure,.. it sounds like it would be a lot more work. there's a formula to figure out how long a port should be.
I'm sure if you did a search you could find the formula.
Old Oct 28, 2002
if you run them outside and some of the box is hidden you can rock ultra long ports, or ports with cool looking ends
Old Oct 28, 2002
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
that's the dumbest thing I ever heard... Do you know why you want super long ports? cuz they would "look cool" I hope not.. you better have a legitimate reason for wanting long ports.
Old Oct 28, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: JohnDoe
that's the dumbest thing I ever heard... Do you know why you want super long ports? cuz they would "look cool" I hope not.. you better have a legitimate reason for wanting long ports.[hr]
Low tuning you putz!!
Depends how long the port actually is..and if you can keep the part hidden that goes outside the box. then it's allright..but to have a fully visible port hanging out the box is jus not cool
Old Oct 28, 2002
JohnDoe's Avatar
well sure.. but from what he's saying that's not why he wants long ports
Quote
[hr]you can rock ultra long ports, or ports with cool looking ends [hr]
doesn't sound like tuning is that big of a deal to him.
Old Oct 28, 2002
WhiteRabbit's Avatar
form follows function. and once you have function, why not go all out in form? for awhile when i was still designng a stereo where i had sidepanels in my car, i was going to run the ports underneath those panels then have the ports fire directly at each other from either side of teh vehicle! (most people i know put 6x9's there....)
but once you hammer out a design, why not go for creativity? could cut a series of holes and route PVC liek a snake into and out of the box [IMG]i/expressions/face-icon-small-wink.gif[/IMG] thought about doing that one [IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 28, 2002
Ed's Avatar
Ed
Man! you thought of that too?!? i've always thought about making the portsin and out of both sides, or around one side to the back or just around the side liek a big handle. enough of me.
Old Oct 28, 2002
mohawkboom's Avatar
hell why not make a small ported enclosure with a pair of 4" ports tuned down to 28hz and have them come out the sides of a plexi glass box and make them look like devil horns??
Old Oct 28, 2002
the reason i was asking, is that someone asked me to design them an enclosure similar to mine (spare tire box) but ported, and i figured, since my trunk floor is raised 3 or 4 inches due to the box, i have a bunch of space to work with under the floor... why not use it to run some ports that come up the side and then end up next to the subs... lemme see if i can draw a diagram...
thanks for all the support there JohnDoe
about super long ports there JohnDoe, i think it was the new diamond subs (feel free to correct me) that have some ludicrously long ports... not sure
but i hope you all see what im talking about now...
Old Oct 28, 2002
port is a function of box, not woofer.
Old Oct 28, 2002
mohawkboom's Avatar
true..but woofers react differently in in different sized enclosures with different sized ports..
the same woofer in 1.1 cu.ft ported tuned to 28hz might sound alot different in a 3.2 cu.ft enclosure tuned to 28hz wth a 2" port [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
some woofers get better response in small low tuned enclosures..some ge better response in larger enclosures..
Old Oct 28, 2002
was in reference to "diamonds have long ports"....
furthermore, port legth and tuning is also related to port area. you tune to 35 Hz with a 2 inch port, its not so big. increase that to 6" and youve got quite a port!
sub performance doesnt really even enter into this yet. its a question purely of port design. which is dependant only on box properties.
Old Oct 29, 2002
fonto's Avatar
The LA Clipper
Ludlam, the way your floor looks is so awesome that i wouldn't want to put ports in and mess up how it looks now.
Old Oct 29, 2002
JohnDoe's Avatar
man.. I got owned.. i should stop posting when i'm in a bad mood. [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Oct 29, 2002
read up fonto, not for me, for someone else
Old Nov 2, 2002
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
the answer is yes, u can have ports stick out, but it's ugly!
if u need long ports but don't have room inside the box, i believe JL makes these weird bent L-shaped ports for small boxes...
Old Nov 2, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
i always wanted to run long a$$ ports sraight into the dash (port wars cheater)
Old Nov 2, 2002
fonto's Avatar
The LA Clipper
I have a friend who made his box as tall as possible, and he made the ports go up through the rear dash. It looks really nice, and gets LOUD!
Old Nov 2, 2002
bake's Avatar
bake is an unknown quantity at this point
yea the diamond subs require like a 54" port.....i looked at those, i seen a box design for them ported and for 2 12" it would take up most of the trunk, so if i get those i'll be sealing them up
Old Nov 2, 2002
turboslug's Avatar
Super Hoser
Quote
[hr]Originally posted by: fonto
I have a friend who made his box as tall as possible, and he made the ports go up through the rear dash. It looks really nice, and gets LOUD![hr]
i've seen it done...it's not really that much louder and the bass doesn't sound quite right...
i think those chimneys are just a waste of space...
burnyd
ECU Fried
May 24, 2018 10:44 PM
99BoostedSi
Sep 7, 2015 04:49 PM
4jacks
Aug 17, 2015 01:26 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
