I found a good site for "learning" car audio
I was trying to understand how different configurations of a 2 channel amp would give me the most power out of that amp and ran across this web site. http://www.faqs.org/faqs/car-audio/ It is a bit out-dated but I found A LOT of good info in there. Hope it helps you.
Oh, BTW... just to help me out.. which config with a Kicker Comp 12 would have the best results.. i.e most power from the amp.
I have an Xtant202 amp running the sub. Here is how I currently have it set up
w=wire
w w
This is what I was thinking, any why I was thinking it, was that I read in a post that electricity can be related to a tank of water with a hose attached.. water will only travel so fast through 1 hose, but if 2 hoses are attached then twice as much water will flow through
wP = positive wire to speaker
wN = negative wire to speaker
wP wN wP wN
remember this is only going to 1 sub in a 2 channel amp... thanks guys
w=wire
w w
wP wN wP wN
THE WOP
I see you used my diagram... much props. I know for a fact that you have to bridge to double you output.
pos to pos in left channel. neg to neg in right channel. but that only knocks you down to 2 ohm. to get more power you have to drop to 1 ohm and then a half ohm. Half will kill your system in less then 3 months. Its for compitition only and amps that can handle it.
The theory on the wires and electricity flow... why not just get a bigger guage of wire?
THE WOP
my bad. Thanks for the site. Found it very helpful on bridging. What I described above is actually the wattage of 1 channel x4 at 4 ohms mono. So basically bridging a 300 watt 2 channel amp would be 150 x 4 or 600 watts at 4 ohms mono. That means I am pusing 1200 watts to my 15". Sweet!!!!!!!!
THE WOP
That sort of helped alot. Now all i got to figure out is if they are talking about going from just the right channel or from + on right and - on left.
But Hey... THANKS ALOT[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Jonas Powell
Apr 16, 2015 11:47 AM
usajags84
Apr 10, 2015 09:54 PM
