2003 Civic Dash Removal
Old Oct 10, 2002
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
I have a 2003 civic, it has an updated console and the beverage holder cover. So, to make a long story short, there is no individual piece where the 12v plug in is to just pop off. What is the easiest way to remove the dash to install a new HU in this car? Has anybody tried or know?
Thanks A WHOLE BUNCH,
Eric
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 10, 2002
Mbow's Avatar
I have a 02 so can't be sure about the 03. You will probably have to revmove the console or at least loosen it so it can be slid backward. After that, you will see two 8mm screws/bolts just above the area where the power outlet is. Remove those and then the whole center dash piece (plastic part that houses the hvac controls, stereo, and pocket)has to be popped out. It is held in by clips similar to those found on door panels. People say to use a screwdriver or something to pry the unit outward until you can get your fingers underneath to break it loose.
However, you can reach behind the unit in the area where you took the screws out and push on it from behind. It takes a little muscle but you should be able to release the bottom clips enough to get your fingers in. This eliminates the possiblity of marring the vinyl dash while prying.
Look at the DIY here and it should make things a little clearer. I would think that the only difference would be your console. It's removal shouldn't be much different or too hard to figure out.
Old Oct 12, 2002
dragoon's Avatar
hey take us some pics of the 03, too!
Old Oct 12, 2002
alright guys...ive tried everything..i'll post pics to members rides ASAP and let you see what im going up against...thanks for any help i can get
eric
Old Oct 13, 2002
well i still need some help. any suggestions?
Old Oct 13, 2002
Mbow's Avatar
You are probably one of the only people with a 03 on the board. I thought you were going to post some pics of the console.
You have a cubby hole that also functions as an armrest right? Well, in the bottom of it there is probably a little door type thing that flips up. Pull that piece up and there should be a couple screws that need to be removed. Other than that, I don't know what to tell you without pics.
Old Aug 30, 2003
Shadow_Saint's Avatar
Shadow_Saint is an unknown quantity at this point
I have an 03 and I just bought a pioneer. I have no idea where to start so I think im just going to get it installed somewhere. . Oh well
Old Sep 1, 2003
greggdogg's Avatar
greggdogg is an unknown quantity at this point
Try the search function
Old Sep 7, 2003
7thgencivic9's Avatar
7thgencivic9 is an unknown quantity at this point
I know how...I have an 03 and i am in the process of painting mine right now...ok remove that horseshoe piece that goes around the 12v outlet piece (it pops off...its hard...but it pops off...be careful not to crack it)...and then it is pretty much pull the 12v piece...and it will come off then
Old Sep 7, 2003
after you get that piece off just remove those 2 bolts that are on that metal bracket then reach up under there and pull out on the bracket and you'll have that headunit piece out in no time...its that easy
Old Sep 7, 2003
seijin_av's Avatar
seijin_av is an unknown quantity at this point
i'll go look for my dads digital camera and try to do a quick diy... the 03 sedan requires some pulling... you MAY think your breaking something but i havent had crease marks. i'll post it in like an hour.
Old Sep 7, 2003
Zeroxxx's Avatar
Zeroxxx is an unknown quantity at this point
Hey, i posted a tutorial at vcc, check it out
http://www.vancouvercivics.com/forum...d.php?tid=9240
Old Sep 7, 2003
seijin_av's Avatar
oh yep... he has a diy. my camera's all asdklfjlakjf but if you still need help just pm me.
Old Sep 8, 2003
Bellz's Avatar
Hey Zeroxxx, that Grizzly guy on that forum probably has a DX, which has the old style 2001 console. His pic looks like a DX also.
Old Sep 8, 2003
Zeroxxx's Avatar
well, he definitely doesnt have what i got. but atleast people with his style car know not to rip that part out with their raw strength. hehe.
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
deus-ex
Apr 13, 2015 12:29 PM
