line out converter?
Old Oct 8, 2002
Les's Avatar
Les
Les is an unknown quantity at this point
line out converter?
I tried to intstall a line out converter (scoshe brand), and something's wrong. Was wondering if there's a limit on how many watts your amp can be, mine is rated at 800 watts, the package says up to 80 or something like that, but the guy said it should work fine. I messed with the input setting on the amp and the loc, but could never get it right. It would either barely play or start clipping.
Old Oct 8, 2002
Les's Avatar
Les
Damn it..rrrrrrrrrrrrrrr...can someone help me out. Now my right front speakers don't work. This is really starting to **** me off!!!!! If I blew my speakers would no sound come out?
Old Oct 9, 2002
Ed's Avatar
Ed
I have no experience with line out convertors, but I'll assume that that 80 watts limit is the limit of the input speaker wire (coming form your HU). Is everythign hooked up correctly? Speaker outputs from the Hu to the inputs on the LOC, then RCAs to the ampifier?
-Ed
Old Oct 9, 2002
Les's Avatar
Les
yeah I figured out the loc, it just happened to be a bad one. I returned it and it works now. Speaker is still not working up front, but at least my subs are now. I have a question though, my subs seem to be clipping every so often. What could be the cause of this? It's really bad if I put in a 2pac cd. oh well, guess i'll learn as I go....thanks for the help
Old Oct 9, 2002
Ed's Avatar
Ed
How are your gains set on the AMP? do you have bass boost/loud/EQ set high?
Old Nov 10, 2002
cdmx's Avatar
I was told to hook up the line-out converter to the front speakers that way you dont get any feebcak from the sub and the rear speakers...try that
Old Nov 10, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
Maybe try a powered line out converter. You may need a stronger signal going to your amps.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
powman02
Sep 15, 2015 07:38 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
