0 gauge wire...
Old Sep 30, 2002
HondaLuver's Avatar
Its a celebration bitches!
0 gauge wire...
where should i run some 0 gauge wire... could i run it through the side pannels? will it fit? and what would be a good 4 channel amp running about 400 watts... is Alpine a good choice?
thanx
My Car...
Old Oct 1, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
you could run it under the center consol. thats some thick @$$ wire. how much power from what kinda amps?
Old Oct 1, 2002
LudlamTheory's Avatar
i boogie for the raindrops
you really only need 4 gauge wire unless you're running some serious power
Old Oct 1, 2002
HondaLuver's Avatar
well im going to run like a 400 watt alpine 4 way and a 1000 watt fosgate sub for a Power HX2 sub
Old Oct 1, 2002
4 gauge
Old Oct 1, 2002
Ed's Avatar
Ed
Quote
[hr]Originally posted by: HondaLuver
well im going to run like a 400 watt alpine 4 way and a 1000 watt fosgate sub for a Power HX2 sub[hr]
I like to power my subs with other subs too [IMG]i/expressions/face-icon-small-smile.gif[/IMG] jk; I know what you mean [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 1, 2002
Subrage's Avatar
4 might be a little small you could go with 2 gauge
Old Oct 1, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I run 0 gauge in my car. I ran the power wire down the passenger side and my signal cables down the driver side. Theres a hole in the firewall below the glovebox with a rubber sleeve, I just fed my wire through that. Then, just pull up the trim on the sides and run the cable under the carpet, there in just enough room for it to fit.. Just find your way to the trunk , its pretty easy to do. I think you have to loosen the seat belt bolts too.
Old Oct 1, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: IDQcivic
I run 0 gauge in my car. I ran the power wire down the passenger side and my signal cables down the driver side. Theres a hole in the firewall below the glovebox with a rubber sleeve, I just fed my wire through that. Then, just pull up the trim on the sides and run the cable under the carpet, there in just enough room for it to fit.. Just find your way to the trunk , its pretty easy to do. I think you have to loosen the seat belt bolts too.[hr]
Exactly how I did it..just ran it like I would any other power wire..there's enough room under the panels to fit 1/0 Guage..Although..if you need 0 Guage wire..you better have a High output alternator..otherwise 4 guage is more than you'll ever need...
Old Oct 2, 2002
Bryn's Avatar
Bryn is an unknown quantity at this point
Quote
[hr]Originally posted by: Ed
Quote
I like to power my subs with other subs too [IMG]i/expressions/face-icon-small-smile.gif[/IMG] jk; I know what you mean [IMG]i/expressions/face-icon-small-smile.gif[/IMG][hr]
haha[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
