Attn: Mohawkboom please help!!
Old Aug 8, 2002
vtexcivic's Avatar
vtexcivic is an unknown quantity at this point
sup mohawkboom i want to ask you something since you're good with i.c.e. well the thing is my cousin installed my alpine cda 7894 deck like last tuesday the same following week on saturday everything shut down.. the cd player doesn't even turn on no more, oem keyless alarm messed up, my dome doesn't turn on when the doors are open only if the key is in the ignition, the lights that lids up with ac button etc blinks with the hazards are on.. do you know what the cause of the problem is? and yesterday my cousin checked the system all the fuses are doing fine.. even the cd player fuses are good.. we also disconnected the cd player from the harness and it still does the same thing.. so you know what causing this to happen please let me know.. because it sucks driving a sooped up car without muzik.. thanks..
Old Aug 8, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
i would put in the stock cd player and take it to honda. that sounds like a major problem
Old Aug 9, 2002
mohawkboom's Avatar
He probably spliced the wires poorly and and taped them up poorly and somthing shorted..but in the OEM HU..
Old Aug 9, 2002
vtexcivic's Avatar
well he sauter (sp) the wires. together that's all i kno
Old Aug 9, 2002
mohawkboom's Avatar
he probab;y frgot to tape them off and 2 of the soldered wires came into contact.. take it to a car audio shop..the delaer might decide to void your electrical warranty.. a car audio shop can fix it..everyshops blown a few in dash circuit boards
Old Aug 9, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
Did you check the fuses under the hood? I installed my friends Alpine 7894 in my car to see how it sounded and when I pulled it out and put my kenwood deck in, the deck would not play and the power doors and keyless entry would not work. I checked under the hood at those fuses and sure enough one was blown, a 15 amp fuse i think, replaced it and everything works fine. I don't remember which one it was so just pull the ones out one by one to find a blown one. Hope this helps.
Old Aug 9, 2002
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
i wired my stereo nicely with wire caps and tape, there's no way this thing is shorting out. but i got a kit for a 98 civic because the guy told me it would work. when i hooked up the orange 'dimmer' wire with the orange power wires, my stereo and parking lights were on all the time when the car was on. it was nice because i could turn on the lights and have the radio without the keys.
if you want this feature, just go to the pasadena best buy and ask for the wire harness for a 2001 civic and you'll get the wrong one for sure.
Old Aug 9, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
That's funny man. Does it work when the car is on but the lights are off?
Old Aug 16, 2002
2k2civic's Avatar
Umm, I don't know what the whole headlight/radio thing is, but I left that orange dimmer wire alone. The only wires that need to be hooked up from the car are the power, acc. , ground wires and if your not using an amp the speaker wires. I left out the little orange wire on both my car and my cousin's car and everything is fine...
BTW, the 98+ Hondas all have the same harness I think. I've had 98+ Civic and 98+ Accord harnesses that both worked on 2002 Civics.
Old Aug 16, 2002
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
Check all the fuses. I guaruntee it's a blown fuse and either the wires aren't taped at all or not well because something definetly shorted. The factory Keyless is messed up because Honda made factory Keyless go through the head unit from 96 or 97 on. You actually have to leave the stock HU under the dash and still connected for it to work and run new wires for an aftermarket one. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
RHCP0801
Oct 11, 2006 10:38 PM
DMikeX
South Cali
Jun 27, 2005 01:51 PM
RIC3BOY
Aug 18, 2003 10:16 AM
Mbow
Transaction Feedback
Feb 14, 2003 12:06 PM
SOHCScreamer
Mar 25, 2002 11:54 PM
