Sound insulation/deaden firewall?
Old Aug 8, 2002
klam's Avatar
klam is an unknown quantity at this point
Has anybody sound insualted/deadened their firewall? What is required to get there, remove the whole dash?
I've done my doors so far.
Old Aug 8, 2002
mohawkboom's Avatar
well removing the carpetting..there's also a rubber pad there with sound absorbing stuff..to remove it properly the dash has to come apart.. I just cut mine off with an exacto..and taped it back on with aluminum duct tape and rubber cement
Old Aug 8, 2002
civicvtec1ps's Avatar
Search and Learn
theres firewall.. right? ^_^
Old Aug 11, 2002
tom1178's Avatar
tom1178 is an unknown quantity at this point
yup that's the firewall. What i did for putting my hole in the firewall......
towards the left side of your picture you can see a bunch of the wires that honda runs through the firewall through a rubber grommet thingy, take a screwdriver and punch through next to where the factory wires went through, stick through a coat hangar with your power wire taped to it, go to the other side of the fiewall and pull the coat hanger and power wire through, then you're all done. But if you want to drill holes through the metal of the car go ahead, just be careful you know exactly where it's going through to.
Old Nov 18, 2002
ziggyziggy69's Avatar
ziggyziggy69 is an unknown quantity at this point
how do i get to the firewall? i know that its to the right of the stereo but i cant seem to locate it. i removed the entire center peice with the stereo and AC vents and i looked behind it but cant seem to locate the firewall.
Old Nov 18, 2002
STang57's Avatar
STang57 is an unknown quantity at this point
ziggyziggy69,
the firewall is not behind your dash...its UNDER it
you can find it on the passenger side...under the carpet around where the persons left foot would be.
its only velcro that holds that part of the carpet down. i dont remember but you MIGHT have to take the kick panel off also
~STEVE
Old Nov 18, 2002
Ed's Avatar
Ed
Quote
[hr]Originally posted by: civicvtec1ps
theres firewall.. right? ^_^[hr]
Woah, i think that's my hand!!!!!!
Old Nov 18, 2002
Quote
[hr]Originally posted by: STang57
ziggyziggy69,
~STEVE[hr]
thanks man. i assumed it was to the right of the stereo cuz if i pop the hood and looked at the wires going thru the rubber grommet, it seems to be located right where the stereo is. but anyways, how do the wires from that location eventually come into the inside of the car and end up underneath the glove compartmnet?
Old Nov 18, 2002
mohawkboom's Avatar
The firewall is the entire sheet of metal your engine and you in the front of the car.. it's what your dash is mounted to..if you open the hood..at the far back behind the engine..whole wall is your firewall..inside the car you can only really get to it under the dash..otherwise your entire dash much be removed..
Old Jun 14, 2005
nindoo's Avatar
Why is my vagina bleeding?
To reduce engine niose, if I put the sound deteaning material in this area alone under the dash would it make an impact, or the only way to reduce the sound is by opening the dash and completely covering the inner firewall area.
Old Jun 14, 2005
paradoxblue's Avatar
wtf...
Old Jun 14, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Very little if any change. There is a lot of stuff there already designed to muffle engine noise.
Old Jun 15, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I never did our cars firewall but I did an Audi TT at work.. kind of a PITA but we did sound damping in the entire car (fire wall, doors, rear body panels, trunk, rear deck, headliner) and he gained 3db off it. Well I guess technically he didn't GAIN it, but you know what I mean
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
