Head Unit Install
Old Aug 4, 2002
LuvDatCivic's Avatar
LuvDatCivic is an unknown quantity at this point
Head Unit Install
What's the best way to pry off the upper dash with the factory radio in it without damaging the dash? Also, I am having a hell of a time getting to the screws directly underneath the unit. I moved the center panel back a bit and I cant get a good grip on the screws. any suggestions? Thanks.
Old Aug 4, 2002
By the way I Have a 2002 ex coupe. Sorry bout that.
Old Aug 4, 2002
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
dude use a socket set to get rid of those two screws by the power outlet, also dont use a philips head because if you round them out your frucked, also the plastic trim with the vents and all, you take a towel and wrap it around a flat head and gently push it under and pull up... its really easy just follow the DIY on the page.
4 banger
Jun 5, 2015 01:44 AM
HondaHomer
May 14, 2015 12:24 PM
mugenca
Apr 16, 2015 12:15 AM
mwwhonda
Dec 5, 2001 10:52 AM
PimpBot5000
Nov 26, 2001 07:15 PM
