How to Secure Sub in Trunk?
Hmm... ok, so I wanted to have the easiest setup in my trunk so that I can yank everything out to carry cargo if needed, so I attached velcro to the bottom of the sub. It worked fine until I decided to take a corner very hard and the sub dislodged... How do you normally secure the sub in the trunk? I'm trying to find a way that isn't too hard to remove if I need to use the whole trunk.
How is it typically done?
In my old ride, I used one of those ratcheting cargo straps. I just looped the strap to some part of the car, and the other loop went around a hook I screwed into my box. The box was pretty much strapped into the corner. Kinda ghetto (ok ok, it IS ghetto), but it works.
Quote
[hr]Originally posted by: JJF
If you are trying to avoid a permanent install, try using a "L" bracket, just keep a screwdriver in the car.[hr]
In my old car, I had a leaky trunk and sometimes water would pool up in the spare tire well where I had my sub box. I screwed 2x4's to the bottom of it and that kept it out of the water and it kept it from tipping over. You probably don't want to do that though. I just mentioned it for some good laughs. Feel free to point and snicker at my old ghettoness.
Fernando The Donkey Lover
Quote
[hr]Originally posted by: UncleB
In my old car, I had a leaky trunk and sometimes water would pool up in the spare tire well where I had my sub box. I screwed 2x4's to the bottom of it and that kept it out of the water and it kept it from tipping over. You probably don't want to do that though. I just mentioned it for some good laughs. Feel free to point and snicker at my old ghettoness.[hr]
Geez Unlce B you are soooo f'n ghetto, hood rat
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Crazygrlinak
Oct 8, 2015 05:06 PM
frank_kleng
Sep 29, 2015 10:55 PM
Sep 27, 2015 11:33 AM
Skunkone
Sep 24, 2015 04:38 PM
