Can The alternator handle this?
Old Jul 22, 2002
3dStylz's Avatar
3dStylz is an unknown quantity at this point
OK I am gonna run two 300 watt amps and a 600 watt amp. So do I absolutly have to change the altornator or get a cap? just wondering.
Thanks for your imput.
Old Jul 22, 2002
mohawkboom's Avatar
300 watt peak?..
what amps..?..
Old Jul 22, 2002
3dStylz's Avatar
ya those are all peaks so 300 watt jensen amp another 300 watt jensen amp and then a 600 watt kenwood amp probably realistically only pulls rms like 120 on the jensen and 300 on the kenwood
Old Jul 22, 2002
mohawkboom's Avatar
your alternator will laugh at you and ask for more [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. yeah it can take that NO PROBLEM
Old Jul 23, 2002
3dStylz's Avatar
Thanks mohawk was just curious, thanks for assuring me
Old Jul 23, 2002
CelCUs's Avatar
CelCUs is an unknown quantity at this point
I'm going to run 1000 watts outta my system once I install it this week . . . I'm getting a 1 farad cap and probably a deep-cycle battery. Will I need to replace my alternator too?
Old Sep 3, 2002
Phatboy's Avatar
Phatboy is an unknown quantity at this point
I'm currently running a Memphis 1000D Amplifier, with no caps, no deep cycle battery... sure my lights, interior lights will dim every time i thump on by, but no altenator/battery problems as of yet. My Amp is currently running 1100watts on 1ohm....
Old Sep 3, 2002
Phatboy's Avatar
sorry for such a late response on the thread, i tend to lack realization of the actual dates these things are posted on, my retailer told me my amplifier "can" draw up to 90amps, I had to buy a breaker! 100amp breaker...[IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Sep 3, 2002
mohawkboom's Avatar
DImming isn;t necessarily a serious problem..anytime you get voltage drop of more than 2 volts..your lights will dim.. not from 13.8- a momentary 11.8 volts is not biggy during hard bass hits..If your running a 1000 watt class D sub amp..and another 2-300 watts of Class A/B Power and love to crank it..you may kill your battery or fry your ECU..It's not likely to happen, But it is a possibility. So the risks are up to you..
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
260000milesgoal
Sep 25, 2015 07:41 PM
speedlever
Sep 24, 2015 07:18 PM
aaronmechanx
Sep 14, 2015 08:45 PM
