Help: Wire through doors
Old Jul 15, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
i was trying to install some of my system today. but i couldnt get the d@m wire through the rubber thing. any and all hints will be very appreciated. i have no music [IMG]i/expressions/face-icon-small-sad.gif[/IMG] so i gotta do it tommarrow.
Old Jul 16, 2002
PK2K1's Avatar
PK2K1 is an unknown quantity at this point
get a metal coat hanger, undo it so it's a straight rod.... make a hook on 1 end, tape your wire on tightly.. then w/ the other end poke a hole in the rubber, it's tough to keep it straight, i had to get my bro to help me... then when you're pulling it through be careful cuz the end (where the wire is) is thicker, and it could pull that rubber right out of your door.
Old Jul 16, 2002
mohawkboom's Avatar
I Used a scalpel and cut holes in the grommets
Old Jul 16, 2002
PK2K1's Avatar
u mean in your doors? or to get your wire to the battery?
Old Jul 16, 2002
dnutz's Avatar
dnutz is an unknown quantity at this point
I used the hanger idea except tied twine on the end, once i got the twine threaded through the gromet I tied some half hitches to the speaker wire and smacked someelectrical tape over that to make it smooth. Took me like 10 min for both doors.. My pain in the *** was the spacer. I ended up buying this stuff called NuFoam, it is 2 inches thich and compressest to what ever you want it to. I cut out templates and put it behind the speaker and screwed through it. makes a better seal than wood from the speaker to the door.
Old Jul 16, 2002
Subrage's Avatar
i tried the coat hanger. i spent about an hour on one door. stll couldnt get it through. going to try again today.
Old Jul 16, 2002
ELaudio's Avatar
ELaudio is an unknown quantity at this point
I had the same problem. The rubber channel thingy is s-shaped, and makes passing wires a serious ordeal. I took the cheezy way out - I passed my speaker wire OUTSIDE of the rubber hose thingy and used silicone to seal both the door end and the car-pillar end. Worked well - havent had any leaks or problems yet...
mohawkboom
67
Aug 25, 2015 12:28 AM
MamaBear2015
May 18, 2015 07:37 PM
werdnahall
May 17, 2015 11:37 AM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
