amps
Old Jul 15, 2002
rp's Avatar
rp
rp is an unknown quantity at this point
amps
i was wondering do i look at the 2 ohm or 4 ohm rating when i m looking for a amp for my speakers
Old Jul 15, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
post in ICE
Old Jul 15, 2002
Vizyun's Avatar
The Fallen Angel . . .
Vizyun is an unknown quantity at this point
Jep, you'll definitely want to post in I.C.E forum. Or just PM Mohawkboom.
Old Jul 15, 2002
QCKSILVR's Avatar
QCKSILVR is an unknown quantity at this point
Thread moved to ICE section.
Old Jul 15, 2002
Ed's Avatar
Ed
If they're for your door speakers, you'll want 4 ohm, most speakers there are 4 ohm.
Old Jul 16, 2002
ELaudio's Avatar
ELaudio is an unknown quantity at this point
If you are talking about door or rear-shelf speakers, you will be running a 4 ohm stereo load. All car audio amps can handle a 4ohm stereo load without a problem.
If you're running subwoofer(s) - you have to be careful. Most amps can be bridged to 4ohm mono (if you are running a single 4 ohm woofer). Now, if you have two 4ohm woofers wired in parallel, you got yourself a 2ohm mono load. If you are doing this, you'll need an amp that can be bridged to 2ohm mono. Not too many amps can do this - be careful, if your amp is not rated for 2ohm mono it will overheat and/or blow its fuse.
As for me, I have two 8ohm woofers in parallel, giving me a 4ohm mono load. My amp is only rated for 4ohm bridged mono operation, so I had to go with this set-up. One more caveat: some amp manufacturers claim their amps to be "2ohm mono stable", and well... often they are not. I am running a low end amp (Sony 1002HX for my subs), and it "claimed" to be stable to 2ohm mono. I tried two 4ohm woofers in parallel = 2ohm mono load, and the amp overheated like mad.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
