when installing brown bread....
Old Jul 11, 2002
PK2K1's Avatar
PK2K1 is an unknown quantity at this point
i just got a 70 sq ft roll delivered today.... so when i'm doing the doors should i take that plastic lining thing off? or just put the stuff on top? do i just slap the stuff on right over the wires and all that?
Old Jul 11, 2002
PK2K1's Avatar
i know u guys know the answer....... [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 11, 2002
mohawkboom's Avatar
Take the lining off..you have to deaden inside the door too [IMG]i/expressions/face-icon-small-smile.gif[/IMG]..then the door. and replace the plastic thing with the Brown Bread!!
Old Jul 11, 2002
PK2K1's Avatar
so i deaden the actual door..... and the door panel? how many layers on each?
Old Jul 11, 2002
mohawkboom's Avatar
2 on the door skin.. 2 on the part where the plastic was.. 1 on the plastic door panel..
Old Jul 11, 2002
PK2K1's Avatar
so what ur saying is i gotta go behind the window? (when the window is down) ok i think i get it (i must seem like a retard)
Old Jul 11, 2002
mohawkboom's Avatar
Window up.. the part that would be the outside of the door.. only you deaden ths inside of it
Old Jul 11, 2002
klam's Avatar
klam is an unknown quantity at this point
Mohawk, I only did two layers on the inner sheet metal (i.e. the door layer where the plastic sheet is stuck to, or the one between the glass and the door interior).
How can you do the door outer skin? There's only a few small holes?
You also did the plastic door panel reverse side?
Old Jul 12, 2002
Slickwillie's Avatar
Slickwillie is an unknown quantity at this point
if you have side airbags, then you probably won't be able to get in there!
Aaron
Old Jul 12, 2002
klam's Avatar
The side impact sensor is there right? I thought I saw a contraption of some sort there.
Old Jul 13, 2002
mohawkboom's Avatar
Side airbags was an option?.. if you don't have side air bags.. you wedge your arms in there.. cut 6" x 12" trips or smaller and cover that ya can [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 14, 2002
klam's Avatar
Side air bags are standard on the Acura EL!
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
