infinity reference components 605cs
Old Jul 6, 2002
ziggyziggy69's Avatar
ziggyziggy69 is an unknown quantity at this point
anyone tried installing this on their 7th gen civic sedan?? planning on buying it but wanna know if anyone has trouble installing it or can provide me with any tips. i have already bought the 1 inch spacers.
Old Jul 7, 2002
swkfilms's Avatar
swkfilms is an unknown quantity at this point
im sneaking into your post. I'm looking at the same components. I'm not going to be able to buy them for a while though. If and when you get them can you let us know how they sound? i'd appreciate it. thanks
marty
Old Jul 7, 2002
TOOLOWCIVIC's Avatar
I wanted to buy these but I would like to know if they fit on the coupe without any spacers or modifications.
Old Jul 8, 2002
Slickwillie's Avatar
Slickwillie is an unknown quantity at this point
I have those in my car up front. They need spacers. All I did was take a couple pieces of dynamat (rammatt) and pile them up ontop of each other. They only need about 1/2 inch more room in back. Then I just screwed them in. I'm running them off a RF 160a2. They sound great, but they sorta need to be amped or else they screech and make your ears bleed[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Aaron
Old Jul 8, 2002
WhiteRabbit's Avatar
slickwillie, could you elaborate more on your discovery of these speakers "screeching"? ive heard that infinity tweets are a bit on teh bright side [IMG]i/expressions/face-icon-small-wink.gif[/IMG] but how did running them on an amp help you? you were running off deck power before? and amplifier mellowed the tweeter?
could you go into a little more detail? im kinda curious.......
Old Jul 8, 2002
TroyA's Avatar
TroyA is an unknown quantity at this point
I've been running the 605cs in my sedan for a year now. I connected them to my Stock head unit without any amp, they're only slightly better than stock speakers with my setup, and after a year of playing with the distortion from the stock HU their getting really scratchy at high volumes.
As for install I just dynamated the area and drilled new holes in the sheet metal to mount the speaker...worked fine. I don't know how much different the coupe is from the Sedan though...
Old Jul 8, 2002
the coupe has zero space behind the metal, a kenwood 5 will fit, but even the sony POS i have dont fit in there fully....
the spacer istn too hard to make and can save you hours of door fabrication (aka tearing it up with a dremel)
biggest problem with the coupe is the TINY hole there, the spacer really helps with that....
Old Jul 9, 2002
by screeching, I mean that they would hit a certain note (freq) and then sorta bleed into another higher note and hurt my ears. As soon as I gave them more power then the deck, they stoped doing this. Now they are more accurate, and the notes don't follow the same trend of bleeding into higher notes. Does this make sence? By the way, this is all at high volume.
Aaron
Old Jul 9, 2002
sorphin's Avatar
sorphin is an unknown quantity at this point
I have this set.. finally after 3 years, got a car i could put it in.. they're right about the clearance prob in a coupe, when i roll down my windows, the window clunks against the magnet (need to move them out a bit more apparently)... sound really good tho.. as for the tweets.. i still can't use em cuz they won't fit in the factory brackets where teh stock tweets are (and i'm not cutting up my door for tweeters) i'd heard that later infinitys are slightly smaller tweeter size wize and might fit.. but haven't gotten to try yet...
Old Jul 12, 2002
just need to know if you guys had any problems installing them. i dont think there is enought room from the speakers to the plastic door panel. did u guys have to fabricate the door panels too?
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
khatib
Sep 9, 2015 10:50 PM
Stock 99
Sep 5, 2015 06:06 AM
