BIG ODD PROBLEM
Old Jul 9, 2002
PK2K1's Avatar
PK2K1 is an unknown quantity at this point
BIG ODD PROBLEM
alright i just installed my infinity kappa 6.5 components (running off a kenwood 1000w amp).... also 2 10" clarion dvc subs (also running off an identical 1000w kenwood amp).... lightning audio distributor boxes.
everything was running fine... sounded awesome... then all of a sudden everything stopped but the deck was still going, no sound.... i checked ALL the fuses, (in the amps, in the splitter, under the hood) they're all intact... what happened?
Old Jul 10, 2002
white97ex's Avatar
white97ex is an unknown quantity at this point
might have blown your pre-amp outputs in the back of your deck if you didn't ground your amps really good...
do your other speakers that aren't connected to the amp work?
Old Jul 10, 2002
PK2K1's Avatar
i don't have anything else.... just the components and subs
i'm gonna plug the stock 6x9's back in to check on that... i'll let u know... thanx
Old Jul 10, 2002
PK2K1's Avatar
the stock 6x9's are running
Old Jul 10, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
maybe you blew your components running them off that 1000w amp.
Old Jul 11, 2002
PK2K1's Avatar
highly doubt it cuz the subs stopped too
Old Jul 11, 2002
mohawkboom's Avatar
Did you check your ground point..also your remote turn on wire?.. ceck for any voltage at the RCA's with your HU on.
Old Jul 11, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
You forgot to pay the electric bill!!![IMG]i/expressions/laugh2.gif[/IMG]
Old Jul 11, 2002
LudlamTheory's Avatar
i boogie for the raindrops
maybe youre overloading the remote load... i have heard this happening... these remote wires arent given very much power, and some of these amps like to suck it in.... try the remote in each amp separately... if that works, time for a 12v relay
Old Jul 11, 2002
PK2K1's Avatar
problem solved..... the fuse under the hood was blown (didn't look blown tho).... on the battery side my tester read about 12 v but on the other side of the fuse only like 1 v.... so i upgraded that to a 100 amp fuse
Old Jul 11, 2002
mohawkboom's Avatar
If the fuse was blown..there's generally a good reason for it [IMG]i/expressions/face-icon-small-smile.gif[/IMG]..
Old Jul 11, 2002
PK2K1's Avatar
yeah i knew it was gonna blow.... it was only a 70... what confused me is it didn't LOOK blown.. it blew like at the base.... so i thought my amps were messed cuz they weren't lighting up, no power was getting there
Old Jul 11, 2002
mohawkboom's Avatar
I'm running a nice 1100Wrms amp and a 110Wrms X 2 amp..and I'm currently using a 60 amp fuse..hasn't blown yet..you might have shorted something at some point..
Old Jul 11, 2002
PK2K1's Avatar
really? well it's working now
Old Jul 12, 2002
ziggyziggy69's Avatar
ziggyziggy69 is an unknown quantity at this point
hey pk, when u installed the kappas 6.5s did u have to dremel the door sheetmetal to get it to fit?
GolNat
Suspension DIY
May 12, 2022 06:49 AM
blaketippett
May 29, 2015 08:02 AM
beveragemp
May 25, 2015 07:11 PM
Jigee
May 9, 2015 11:18 AM
bsmiley
Apr 27, 2015 01:27 PM
