ATTN: WHITERABBIT....?'S ABOUT FIBERGLASS
Old Jul 3, 2002
durkinz's Avatar
durkinz is an unknown quantity at this point
hey yo to mold the fiberglass to the exact shape of the counsel and the upper deck area, how did you do it? did you like take the original things and like fiberglass over it? doesnt the fiberglass stick to the stuff? also how do you like screw the fiberglass in? like mounts on the back?? thanks alot!
chris
Old Jul 3, 2002
WhiteRabbit's Avatar
i used my old deck install piece, glued a piece of thin cardboard over it to hold shape, then glassed directly over that.
if i had to do it over again (if haha, WHEN) i would grind off a good 1/8th inch off teh surface of the install kit so the fibercarbon was flush with the dash, or just glass the dash to go with it.
then yeah, i just reinstalled it they way it was before with my deck in there.
if you were doing the whole panel, it would be just as easy to not use anything, leave the hole in there, cover it with paper, make sure its flush with the rest of the panel and glass away. keeps down ion internal clutter....
Old Jul 3, 2002
and with the cardboard glued (industrial strength epoxied) to the install kit, and the fibercarbon way pasted to teh cardboard, its not goign anywhere
General DIY
Sep 25, 2015 08:02 PM
KronikScott
Jun 9, 2015 08:00 PM
djdefcon
17
Apr 6, 2005 11:52 PM
2cute
May 20, 2002 02:14 AM
