amp to power components?
Old Jun 20, 2002
PK2K1's Avatar
PK2K1 is an unknown quantity at this point
this might be a dumb question... i think i know the answer but i'll ask just in case... but, can i power my components using a 2 channel amp?
and.. what do u guys think of a set up like this... 2 10" subs and 6.5" components in the doors... removing the stock 6x9's.. should i have something back there or will this sound good?
Old Jun 20, 2002
Ed's Avatar
Ed
Yeah, you can use a 2 channel amp for the two front channels. Also, you don't really need speakers in the rear, it sounds better with the sound coming from in front of you.
Old Jun 20, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: PK2K1
and.. what do u guys think of a set up like this... 2 10" subs and 6.5" components in the doors... removing the stock 6x9's.. should i have something back there or will this sound good?[hr]
Sounds quite good. Have any ideas yet on what equipment you'll be using?. We can help ya out with deals for good stuff if needed.
Cheers
Mohawk
Old Jun 20, 2002
PK2K1's Avatar
i've got a kenwood mp3 deck (don't know the model # off the top of my head)
infinity kappa 6.5" components
2 10" clarion dvc subs powered by a kenwood kac-929 1000w amp.... and i know a guy who's selling this same amp so i'm thinking of buying it for the components cuz i think it would look cool in the trunk if i had 2 matching amps.
Old Jun 21, 2002
PK2K1's Avatar
as for sound deadening... i read somewhere that someone got stuff from home depot and that it works pretty good.... anyone know anything about this? cuz i'm not really to excited about paying insane amounts of $$ for dynamat or brown bread or anything like that.
Old Jun 21, 2002
mohawkboom's Avatar
if your in the states 1 rolls or Raam60 will doe the trick to get your trunk lid, rear deck, and Doors completely dead... it's $99+SHipping US.
Old Jun 22, 2002
noahnoah's Avatar
noahnoah is an unknown quantity at this point
yea that 2-channel amp will work fine on those components, but that kenwood kac929 is a pretty good amp for those highs you should have a little bit of headroom which should keep your amp running efficiently and cool. As far as no speakers in the back, if you could only have one set of speakers I'd go with the front. If you're a music lover like I am you'll be missing quite a bit of music with no rear speakers. I like to be engulfed in music, and the all around sound. I think the components by themselves will be okay, but with the rear speakers also it should sound badass.
Old Jun 22, 2002
PK2K1's Avatar
thanks guys
i'll install what i got, then if i feel i need speakers in the back i'll get something.
Old Jun 23, 2002
PK2K1's Avatar
Quote
[hr]yea that 2-channel amp will work fine on those components, but that kenwood kac929 is a pretty good amp for those highs you should have a little bit of headroom which should keep your amp running efficiently and cool. As far as no speakers in the back, if you could only have one set of speakers I'd go with the front. If you're a music lover like I am you'll be missing quite a bit of music with no rear speakers. I like to be engulfed in music, and the all around sound. I think the components by themselves will be okay, but with the rear speakers also it should sound badass. [hr]
I was just reading the manual for my amp and it says that if the speakers are rated at a lower power than what the amp is outputting, it will smoke and cause damage.... why would it do that? i mean i would think it would be able to do the job more easily... what's the deal there?
Old Jun 24, 2002
PK2K1's Avatar
anyone?
Old Jun 24, 2002
mohawkboom's Avatar
A <ower impedance will mean the amp will draw more current.. more current draw=more heat.. It can handle a 2ohm stereo load..4ohm mono load
NoobyKid
Jul 13, 2015 07:53 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
hayden55
Jul 8, 2015 11:38 PM
