SVC vs DVC
Old Jun 19, 2002
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
SVC vs DVC
ive searched in the forums for the pros and cons of SVC and DVC subs. im thinking of running either 2 12 inch Cerwin Vega HED or 2 12 inch JL W3's in SVC or one DVC sub. which is the better choice. i listen to heavy rock and club music mostly
Old Jun 19, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
A DVC sub gives you options on how much power you want to send to those subs. At 2 ohms, the amp will provide more power than at 4 ohms. I dunno about one DVC verses 2 CV's or JL's, unless that DVC was an IDMAX, or an Audiomobile MASS. What kind of Amp are you going to use?
Old Jun 19, 2002
mohawkboom's Avatar
There are no pros or cons of each..it's just matter of wiring options to achieve certain ohm loads...
Old Jun 19, 2002
thanks mohawk, just one more question, whats better, the cerwin HED's or the JL w3's? i listen to hard rock and club music mostly
Old Jun 19, 2002
mohawkboom's Avatar
HED's are entry level subs which are very very good entry level subs..but W3's are midlevel subs and are a bit better quality..but also about double the price..
Old Jun 20, 2002
WhiteCivic's Avatar
WhiteCivic is an unknown quantity at this point
What you are planning on running for an amp is an important factor. If your going to be using lets say an Orion 225HCCA which is stable to a 1ohm mono load..then sky is pretty much the limit. But if you choose to go with a amp that is 2ohm STEREO...at best..then you are a bit limited in what you can buy...unless of course you have room for multiple subs to get the load you desire.
Old Nov 18, 2007
americanwarrior's Avatar
americanwarrior is an unknown quantity at this point
Re: SVC vs DVC
Hi i am new to this. I have a question to ask i am buing a cerwin vega 15 inch HED/DVC 4 ohm dual voice coil sub. And the amp that i have is a HiFonics Mercury x 2x50 watts 2/1 channel 1ohm stable amp. Now will this amp push this sub and how should i hook this up?
Old Nov 18, 2007
Re: SVC vs DVC
"anyone"
Old Nov 18, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: SVC vs DVC
this was covered already in a thread from JROCK,
and use google and find out what amp you are getting and what it can do and handle?
iLLuMiNaTi
May 31, 2003 03:40 AM
GOTSPRINGROLLS
Canada West
May 2, 2003 01:44 AM
OyD
Dec 9, 2002 06:08 PM
mohawkboom
Oct 21, 2002 11:52 PM
ZVotypka
Apr 1, 2002 03:59 PM
