help installing playstation2
Old Jun 10, 2002
CivicPunker17's Avatar
CivicPunker17 is an unknown quantity at this point
i just picked up my ps2 from best buy and the dorks there had no idea about an adaptor to plug it into the car. i know theres one i need but im not sure which one so does anyone know?
Old Jun 10, 2002
02CivicEX's Avatar
02CivicEX is an unknown quantity at this point
when u find out let me know, i wanna do the same, but not sure what i need
Old Jun 10, 2002
WhiteRabbit's Avatar
once you have power, the rest is mindless. what you are looking for is a HEAVILY regulated powersupply that will transform 12V power into teh proper voltage and amperage to power your ps2. Check the plug your ps2 came with, that should say 120V 60 Hz AC, and then it will say what teh output is. this is what you want as the output for your powersupply, only differing by the input voltage (12-14V, of course).
no matter where you buy your supply from, no not forget to tell the guy at teh counter what you are using it for! this powersupply needs to put out EXACT voltages for your ps2, you dont want to fry your ps2 after hooking up everything and finding out it works great, just to start teh car, bump teh voltage to 14, spike your ps2, and fry it.
your alternator is by no means regulated! it will send spikes all over the place, and if you are not 100% sure your powersupply for your ps2 cna handle those spikes, your ps2 will be doomed just like all these posts of people here saying their ECM fried. all it takes is a single spike, just like a bolt of lighning, come to fry your s h i t.
If you were in northern california, I would tell you to go to a place called "Quement Electronics" on bascom avenue. That place sells ANYTHING you need to do anything. I bought a powersupply there to rum car amps inside my home, and they know their s h i t. Dont go to your neighborhood radio shack, they wont know the difference between a phone charger and a ham radio powersupply (exept one costs $100, and the other doesnt.)
find a die-hard hard-core electronic supply warehouse in yoru area, they will know EXACTLY what you need to get your s h i t running.
Old Jun 10, 2002
VNlilMAN's Avatar
The Standard One
my friend just put one in his tahoe a couple months ago....
THEY DONT HAVE AN ADAPTER FOR THE PS2 only the ps1. i called sony and they said they dont recommend using the ps2 outside the home so they didn't make one...
but to get power, you need a power inverter. not sure about the wattage, i'll check next time i get in his car. he has it hooked up to his cigarrette lighter but i dont think its safe. would recommend you to hardwire it to the battery directly. the power inverter basically lets you plug in any regular home appliance just as long as the power inverter's wattage is high enough. even has a fuse so you dont fry your ps2. should be about $50 at a place like *cough* radio shack *cough*.
for the sound, he's using a FM modulator
Old Jun 11, 2002
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
just go get a power inverter and take off the little cig plug and plug the two wires to a 12v wire somewhere and youre set. thats what i did and it worksgreat . ive got the ps2 and inverter under the driver seat and a changer under the pass seat
james
Old Jun 11, 2002
i got it all figured out now, thanks for the help guys! i also needed some adaptor to plug the sound into the headunit but its all up and running now!
Old Jun 19, 2002
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
do you have a bus audio in? what adapter did you need to hook up the rca's to your hu?
eric
Old Jun 19, 2002
yeah i needed the bus audio in adaptor, sony makes it
Old Jun 20, 2002
you couldn't just plug the rcas straight into the rca in's? or maybe yours is different, what does this bus adapter look like?
Old Jun 24, 2002
zelman's Avatar
zelman is an unknown quantity at this point
is this to connect to the stock head unit? I want to know more about this bus audio in adapter as well.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
