6.5” Speakers Don’t Fit
Old Aug 25, 2019
coy499's Avatar
coy499 is an unknown quantity at this point
I bought a pair of 6.5” Kicker Coaxial speakers and I can’t find a way to mount them in the rear. I have tried to resuse the old speaker’s plastic frame but I can’t get clearance between the screws and the sheet metal for that.
Old Aug 25, 2019
Re: 6.5” Speakers Don’t Fit
I'm assuming you have a sedan since you're trying to fit 6.5s in the rear deck? Got a picture of what you're running into?
edit: also, is it safe to assume you removed the rear deck plastic in order to install these speakers? I had to do that in my 2002 coupe. I also had to drill out mounting holes and use clip nuts to mount my speakers
Old Aug 25, 2019
coy499's Avatar
I don’t know how to mount it from here
Old Aug 25, 2019
I legit drilled out holes and used these and some sheet metal screws to mount my rear speakers in my 2002 coupe
Will those speakers clear the underside of the plastic deck cover?
Old Aug 25, 2019
coy499's Avatar
They clear the plastic part. How would I drill the holes. My speakers came with some of those metal brackets.
Old Aug 25, 2019
With the speaker in place where you want it, mark where the mounting holes for the new speaker are (pencil, center punch, scratch awl, etc). Remove speaker, and drill holes large enough to accommodate the new screw. If you can find a way to make sheet metal screws (or otherwise) bite into and securely hold onto the metal part of the deck, then cool beans, you don't have to worry about getting the clip nuts. Bonus points if one mounting screw hole for the OEM speaker (or if multiple mounting holes) line up with the kicker speaker's mounting holes.
The metal brackets the speakers came with, what do they look like?
got2run5
Jan 6, 2012 10:19 PM
diablo69
Jan 23, 2005 05:36 PM
jttegx
Jan 5, 2005 10:20 PM
cmann
Jan 3, 2005 12:16 AM
Amer786
Oct 5, 2002 11:30 AM
