Bigger alternator
Old Mar 11, 2019
KiteKing86's Avatar
KiteKing86 is an unknown quantity at this point
Bigger alternator
I was wondering if an Accord alternator would fit 05 civic d17 motor. My alternator can't keep up with my electrical demands.
Old Mar 12, 2019
Colin42's Avatar
Re: Bigger alternator
doubt it, there are companies that make more powerful alternators for the audio guys
Old Mar 12, 2019
Colin42's Avatar
this guy put in a 220 amp one
https://www.civicforums.com/forums/1...gen-civic.html
Old Apr 5, 2019
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
An Accord alternator would not fit unless you made some kind of custom bracket. Also, be careful with the cheap "high output" alternators since most of them are junk from my experience. However, if you don't need a crazy powerful alternator, what I discovered is that an OEM Honda Stream 1.7 alternator is actually much stronger than the Civic alternator and it's a direct bolt on. You can get them for around $60-70 on eBay. I read that they are 95 amps, although I am not certain about that. However, I have one on my Civic with a 48MM pulley and it produces around 75 amps at idle and around 100 amps at about 2000 RPM, so much better than stock. I hope this helps https://www.ebay.com/itm/JDM-D17A-01...Yetb:rk:1:pf:0
https://www.ebay.com/itm/JDM-2001-20...8AAOSwf15aZ1C~
Rice.chrispy
General 7th Gen
Aug 2, 2018 03:15 PM
grncivic2001
Feb 10, 2007 06:37 PM
Sivion
Jul 4, 2003 02:57 PM
chefjnr
Nov 19, 2002 06:20 PM
bake
May 18, 2002 04:47 PM
