Cruise Control, Horn, and power locks not working
Old Aug 5, 2018
fort_em2's Avatar
fort_em2 is an unknown quantity at this point
Cruise not working - light on the button and dash don’t turn on. Horn doesn’t work. Not sure if related but power locks not working either.
It has been sitting and I just noticed this so it may be related - I swapped a broken relay from my civic to my FIL’s civic and I can’t remember which one. I checked fuse 7 under the hood just to make sure and it isn’t that.
Any ideas??
Old Aug 6, 2018
Re: Cruise Control, Horn, and power locks not working
Light on the dash switch could just be a burned out bulb. That's common, all you really need to make sure is that the switch is clicked to the IN position instead of out. .
Check if horn relay clicks when you push the horn button.
Both of these systems inop COULD indicate a clockspring problem but more testing is needed before drawing that conclusion, because each of your complaints COULD be completely separate issues with no common cause.
Power locks.....lots of possibilities.
Check ALL FUSES in BOTH fuse boxes.
Old Aug 6, 2018
fort_em2's Avatar
Got the horn working...bad relay. So just the cruise and power locks. Cruise doesn't work, but both bulbs were working last time it worked.
skj88
Electrical
Mar 30, 2025 06:31 PM
OKCEM2
Electrical
Jun 6, 2019 09:46 PM
Mike4831
Aug 21, 2005 10:29 PM
Storm897
Jan 15, 2004 10:26 AM
Matt
Dec 4, 2002 09:00 AM
