SEDAN rear deck....../ trunk ...anybody with a sedan
Old May 19, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
anybody with a sedan tried to fix the rattles the trunk gives with subs pounding it's sooooo loud ....way louder than other cars i hear.......i tried to fix it quick so i stuffed the trunk lid with styrofoam.....yah it's ghetto but it works .....think it's the 2 metals inside rattling on eachother......what have you guys used on your sedans to stop that horrible rattling???
what rear deck seems like the bass in my car now after i took it out to install my speakers .....the deck now rattles against the window .....anybody know what i should use to fix that up because its annoying when i'm just using the low bass and it's rattling like crazy......what should i stuff with what also.??????????
Old May 19, 2002
mohawkboom's Avatar
We tightened the trunk latch[IMG]i/expressions/face-icon-small-smile.gif[/IMG]..that kills 80% of the rattling..
Also removing the plastic rear deck and using Gasketing foram tape underneath it will stop the plastic from buzzing on the metal there...
Cheers
Mohawk
Old May 19, 2002
HeRbaLuS's Avatar
gasketing foam tape...hmm where can i pick some of that up?? how much is that?
and along what should i tape it ?
Old May 19, 2002
mohawkboom's Avatar
Wal mart..it's a roll of foam that's stick on one side.. stick it to the metal under the rear deck to keep the metal and plastic from making any contact...
Old May 19, 2002
WhiteRabbit's Avatar
i still have to move the latch, but doing the screw thing for the trunk helped a teeny bit. expanding foam killed almost every single rattle in my trunk, i highly reccommend that. hopefully after i move the latch, itll be DEAD
as for my rear deck, i deadened the deck and teh panel, and so no more platic/metal rattling problems. a definite good thing to do. but something else to watch out for is the deck rattling against teh glass of the window as well. I havent decided how im gonna take car of this yet, im thinking im just gonna get some cork and wedge it in there, i think that should about do it. but thats another possible rattle to look out for.....
expanding foam by FAR is teh best sound deader on teh market to date [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old May 19, 2002
HeRbaLuS's Avatar
how does that expanding foam work never heard of that how much that cost and where to get it from.
Old May 19, 2002
costs $3 a can at a hardware store. you put it between the cracks of any metal that vibrates against itself (your trunk lid) then it expands and sets teh metal dead against itself so nothing can rattle. my rattle problems DISSAPEARED after that stuff.....
(be conservative with application, test it first on something)
Old May 19, 2002
mohawkboom's Avatar
also make certain it's minimal expanding foam..if you get the regular tuff and use too much you'll buckle the metal panels..
Old May 19, 2002
blackasnight2001's Avatar
blackasnight2001 is an unknown quantity at this point
i dont' have subs yet but i was just wondering if having a oem spoiler on top will lead to more rattliing or less (cause its heavier)??
Old May 19, 2002
if you use too much of minimal, itll buckle. i used minimal cause it was cheaper, my buddy got regular and kinda over sprayed a bit in my opinion, no buckling. it WAS a mustang, tho.....
you can get the super expanding stuff too! just gotta look out for that.... always test first!
Old May 19, 2002
<< i dont' have subs yet but i was just wondering if having a oem spoiler on top will lead to more rattliing or less (cause its heavier)?? >>
only one way to find out... [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old May 19, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
Im confused.....what is the trunk latch?
Is that the little U shaped thing where the lock on the trunk lid itself holds onto when the trunk is closed? Or are we talking about the lock part that's on the trunk lid?
Old May 19, 2002
<< Im confused.....what is the trunk latch?
trunk lid. the u shaped thing is bolt on, no adjustability
Old May 20, 2002
Yeah I understand now....thanks Rabbit
I actually did a search (WTF is that!??!?![IMG]i/expressions/face-icon-small-cool.gif[/IMG] ) and I found this...
Old May 20, 2002
Purple2001Civic's Avatar
Purple2001Civic is an unknown quantity at this point
well all i can say is that i did move the trunk latch and it did cut down on the rattle just a little bit of rattle left gonna try dynamat the rest of the trunk and see if that helps any, going to do the rear deck as soon as i can will let yall know what i did
JohnnyBxo
Nov 12, 2015 03:04 PM
Nalmonte
Jul 22, 2015 09:08 AM
muttleytm
Jul 14, 2015 05:31 PM
OptimisticWay
Jul 10, 2015 04:31 PM
SpecialRequest
Jul 7, 2015 07:52 PM
