AGM Battery?
Old Apr 11, 2016
shaejb15's Avatar
shaejb15 is an unknown quantity at this point
AGM Battery?
SUP Nation!
In need of a new car battery. Had a Motomaster POS Canadian Tire Battery, and after some research i'm thinking AGM. I am right in the city so the AGM charging part makes lots of sense for me to get, but I am also seeing things about how charging systems in older cars aren't used to AGM batteries and may overcharge in super long trips, but the voltage difference is extremely low? Most of my trips are fairly short within the city. What are your guys's thoughts or experiences with AGM batteries? I've got an 02 civic coupe LX.
If I were to be getting an AGM it would be Motomaster Ultra AGM or Yellow-Top Optima. One thing I have noticed with AGM is CA/CCA are lower compared to some offered in regular acid.
Thanks!
Old Apr 11, 2016
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: AGM Battery?
Actually, I think you are more likely to under charge it than over charge it. As long as your alternator stays under 14.9 volts, you will be fine. You will probably need to top it off occasionally if you do a lot of short trips.
miatabro
May 18, 2016 06:54 PM
Hani4g
Oct 31, 2015 02:09 PM
PatrickR02
Oct 25, 2015 08:08 PM
morkys
Oct 25, 2015 09:29 AM
CapYoda
Nov 11, 2001 05:17 PM
