01 civic driver side won't lock
Re: 01 civic driver side won't lock
The **** stays up while the door is open or closed and the door remains unlocked. Even if I turn the key to lock the door from the outside the **** goes down then goes up while I take the key out.
Several possibilities, someone needs to do more inspecting to see what happened.
Sounds like it's time to pull the door panel off to inspect the lock, linkages, and latch.
Maybe a liberal dousing of penetrating oil could help free up stuck parts?
The answer I'm getting from a few places is the actuator. Does this sound like a possible reasoning?
But if I understood correctly you said yours won't work by hand nor with the key --even with the door closed, so yours sounds like a mechanical/physical problem, not electrical.
NOTE: IF you weren't already aware.... The drivers door must be completely closed before you can lock or unlock it.
NOTE2: With the drivers door open, you can pull out on the inside or outside handle and then you should be able to operate the lock mechanisms, manually or power.
This feature is explained somewhere in the owners manual, if you have it.
That sounds more like something an American car would do.
You could remove the latch from the door, then remove the power lock actuator from the latch, then see if it works.
The electric power lock actuator is available separately from the door latch if you do find it to be faulty.
Honda calls the latch a 'lock' though, and they show it in the catalog with or without the power actuator.
nixyfior
Sep 14, 2015 08:32 PM
