Voltage
Old Oct 25, 2015
PatrickR02's Avatar
PatrickR02 is an unknown quantity at this point
Voltage
Hay everybody,
I'm new here but not at the least new to the automotive area.
Heres whats going on. I have a volt tachometer and started to notice some fluctuation in the reading. The tachometer will read 14 volts for most of the time I drive. Once in a while it will read 12.4v or 12.5v.
I have researched and read where 14 volts are good. But is that not the alternator charging? if so the alternator should only charged for like 30 seconds or maybe even a minute, right?
Also, I know there are different modes for the ECM to operate at if that is the case...or am I being to precise about the readings
New battery and alternator installed.
PatrickR02
Old Oct 25, 2015
Re: Voltage
What you see is normal for Hondas. Read up on Hondas ELD system for more info.
Click this PDF LINK
HTH
Old Oct 25, 2015
Re: Voltage
When I had a voltmeter in my car, it fluctuated anywhere from 11.9 to 14.2VDC during normal operations
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
cferry7
Oct 4, 2015 02:15 PM
morkys
Oct 3, 2015 02:41 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
