Which wire will cut off engine for security reasons?
Old Jun 21, 2014
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
Hi, my searching didnt come up with anything.
can someone please tell me which WIRE I can use as a security cut off (on/off) switch, Where and what color are the wires? Do i need a relay or not?
what would you recommend for a no start cut off switch?
7th gen 2003 civic sedan EX Auto
Thank You! Have a Great day!
Old Jun 21, 2014
sicken04's Avatar
sicken04 will become famous soon enough
Re: Which wire will cut off engine for security reasons?
I dont remember the fuses in my old civic but you could pull the spark fuse(possibly add a switch inbetween?), I never did it to my civic but we did do it as a prank on a friends subaru sti
Old Jun 21, 2014
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
i think most of the time it's a relay on the starter wire. so if the alarm goes off then the starter is disabled and therefore you can't start the car and drive off with it. not sure of the exact wiring though
Old Jun 21, 2014
Stock 99's Avatar
There are several different wires you can cut to install a kill switch. I have 2 kill switches in my car. Unfortunately posting about it online only makes it easier for people to understand how to bypass them. You would only need to use a relay if you were using a low amperage switch on a higher amperage line.
I'm sure if you google 'kill switch' you'll find some ideas though.
Old Jun 22, 2014
lowlife9's Avatar
you don't need a kill switch your car has an immobiliser so unless someone has time to break into your car and then swap your ECU out i think they would also have time to find your kill switch plus nobody steals 7th gen civics. if somebody really wanted your car they would just tow it.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
usajags84
15
Aug 19, 2015 03:12 AM
jetcare101
May 8, 2015 01:33 PM
pincookie1
May 4, 2015 12:22 PM
