Problems after installing new HU
Old Jan 6, 2014
wix256's Avatar
wix256 is an unknown quantity at this point
I just installed a new radio in my friend's 2004 civic hybrid and it's not working along with other electrical problems now. I accidentally wired the dimmer wire to the illumination wire at first. Perhaps I blew a fuse? They all look fine though.
So, now the door locks(along with keyless entry), radio, lights around shifter, IMA light is on and a CEL. When I went to scan the CEL code I couldn't get access.
Please help!
Old Jan 6, 2014
Re: Problems after installing new HU
This smokes a circuit trace right out of the gauge cluster circuit board. Seeing that you did it to a hybrid, it may be worse ($$) than a regular Civic.
Disconnect the radio, disconnect the mis-wired stuff.
Read this thread, there are great pictures of the smoked circuit on the gauges board: https://www.civicforums.com/forums/36-mechanical-problems-vehicle-issues-fix-forum/354532-installed-new-radio-dashboard-illumination-not-working-smoke.html
Locks, keyless, and radio: You probably blew the 'backup' fuse in the engine compartment box.
CEL and IMA...... Fix the backup fuse first.
HTH
Old Jan 7, 2014
GolNat's Avatar
Prelude Owner
For your next radio instal I would suggest getting an adapter harness like this:
Makes instal faster, cleaner and can be returned to factory easily. Crutchfield,
Amazon and sonic all should have them.
4 banger
Jun 5, 2015 01:44 AM
beveragemp
May 25, 2015 07:11 PM
Youshoe
May 22, 2015 09:36 PM
PimpBot5000
Nov 26, 2001 07:15 PM
Flatlander
Nov 16, 2001 05:38 PM
