Constant Voltage Supply for Head Unit
Old May 8, 2002
Glassdome's Avatar
Glassdome is an unknown quantity at this point
Hello,
I have a 2001 Honda Civic LX. Can anyone recommend a fused constant voltage supply (i.e., one that always has potential even when the engine is off) to connect to a CD receiver to? Since the original radio/casette could only be turned on when the ignition key was turned (to any other position than "off"), I'm assuming that there may not be any constant voltage wiring available in the original harness. Then again, something must be there for the station memory, clock, etc to work. Any thoughts?
Timothy Lee
Old May 8, 2002
mohawkboom's Avatar
there is a constant 12v input..which serves that function.. It's connected via a relay to the rest of the HU's functions..then the ignition lead gets a 12 volt signal it turns on the relay and the rest of the HU...you can run 2 12v constants in and use a switch to turn the HU on and off and not have it rely on the ignition lead...but..why?..
Cheers
Mohawk
Old May 9, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
Old May 9, 2002
durk's Avatar
durk is an unknown quantity at this point
ok, dont touch the 12v constant and the 12v ignition wires!!! fuses will blow.....what you want to do, is take the cd player out, doesnt matter and connect the 12v ignition wire from the harness coming from the cd player (red) to the 12v constant wire (yellow)and there ya go this only works on aftermarket cd players tho......
durk
Old May 10, 2002
mohawkboom's Avatar
No worries about blowing fuses..just disconnect the negative battery termnal before touching any wiring...
oblivious9
Jan 25, 2002 10:28 PM
rawtalent14
Jan 22, 2002 09:29 AM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
