2001 EX coupe dash lights
Old Nov 23, 2013
  #31
mapleridge's Avatar
mapleridge is an unknown quantity at this point
Re: 2001 EX coupe dash lights
So I pulled the stereo and the wires for the bulbs were unplugged. I plugged it in and everything was fine. That solves that. Although, this mysterious wiring was found after I opened it all up.......
Any clues...?
This car has been problems from the start. The heater wasn't blowing hot so I wanted to see if AC was on or not. Now the temp fluctuates between medium and max. I just changed the thermostat and radiator cap. We'll see how that goes. If you guys can help with this mysterious wiring, I'd appreciate it.
Old Nov 23, 2013
  #32
It's not mysterious.
It looks like a radio harness. The white plug looks like it went to a non-factory radio or some other accessory. (external CD player maybe?) I assume the other end would plug into a factory harness? Or adapt to something else. IDK.
Was it not connected to anything at all when you found it?
voblak2
20
May 4, 2023 02:08 PM
LionSpratt
Apr 26, 2015 01:02 PM
twtron
Apr 17, 2015 12:09 AM
1028CiViC
Nov 18, 2001 05:45 PM
CapYoda
Nov 11, 2001 05:17 PM
