Power Door Lock Issue
Old May 29, 2013
manster972's Avatar
manster972 is an unknown quantity at this point
The drivers side power lock wasn't working for the past couple of months, so over the weekend I finally got around to replacing the actuator. I had the same issue a few yeas ago on the passengers side. Issue here is that after replacing it I made sure to test it before putting everything back & it was fine. After putting the door panel back & connecting everything I tested it at least a dozen times & everything was working as it should. So the next day it was fine when I used to key less entry in the morning, but later in the day it stopped working again. I'm wondering if anyone has any suggestions on what may be the issue, since I doubt the new actuator will burnout In just one day. The passengers side is working as it should, so the issue is strictly on the drivers side. I'm looking for suggestions before I take everything apart again. THX
Old May 29, 2013
CraigW's Avatar
Re: Power Door Lock Issue
Intermittent connection in the door harness... or elsewhere.
Old May 29, 2013
manster972's Avatar
hope it's just a loose connection somewhere, I'll take another look into it this weekend.
roverben
Jan 21, 2019 05:16 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
