Power door locks work (occasionally)
Old Oct 23, 2012
tsp0054's Avatar
tsp0054 is an unknown quantity at this point
I recently purchased a 2001 Civic Lx coupe. I knew the power door locks did not work when I purchased it, however the locks work sometimes.
I initially thought it was the fuse until I realized the locks work sometimes. I still checked the fuse and it was fine. Any suggestions on how to fix this?
Old Oct 23, 2012
tsp0054's Avatar
Re: Power door locks work (occasionally)
I forgot to mention the drivers side lock will not lock manually. (I cannot push the lock to either lock or unlock.) Is this the actuator? Also if the drivers side actuator has gone bad this should not have anything to do with the problem causing the passenger side door to lock or unlock, correct?
Old Oct 23, 2012
Actuators get weak. If you pull the door panel and check for power and ground at the actuator while operating the locks, that should indicate the next step.
If I see one that moves (or attempts to move) on the first try, then quits, I bet it is a weak actuator. I already know the wiring must be at least good and fuse is good because it tried to work.
You have to pull one of the handles (inner or outer, either one) before you can lock the drivers door with it open.
When the door is closed, it should lock and unlock normally. Honda has done this for decades and only recently moved away from it.
HTH
Old Oct 24, 2012
tsp0054's Avatar
I will pull off the door panel this afternoon and check it out. You are correct about the door unlocking and locking when I pull the handle. At least for now I can manually lock/unlock my doors.
Im trying to fully understand this...... if the actuator on my driver door is weakening or going out, why does my passenger door not work normally when I lock and unlock the doors?
Thanks for the help!
Old Oct 24, 2012
Does it work at all?
They are the same age. Same issues are likely.
But test. Don't guess.
When using the factory remote (all doors closed), normally the drivers door must unlock first before any other doors can be unlocked by the control unit. All should lock at the same time.
When using just the power lock button (all doors closed), all door locks should operate together.
HTH
roverben
Jan 21, 2019 05:16 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
Thees1
Apr 14, 2015 08:23 AM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
