What is wrong with my factory head unit?
Old Oct 21, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
2001 LX
About one minute after starting the car the lights in the head unit will dim out to no light and then come back on about two seconds later.
What causes that?
I noticed it after randomly holding the bottom three buttons in different sequences hoping I could get the AC compressor to turn off when the defrost is on.
Ignorance is bliss!!!
Old Oct 21, 2012
GolNat's Avatar
Prelude Owner
Re: What is wrong with my factory head unit?
Maybe a loose connection behind the headunit. I would pull it out and make sure the radio harness is tight. Your car lowered? Maybe loosened from stiff suspension ride.
Old Oct 21, 2012
Originally Posted by Biscuit
2001 LX
ok....
What causes that?
Absolutely no idea WHY it would happen, maybe it has something to do with:
Now why would you do this? The radio is separate from the HVAC. If there is some button dance, it should all be on the HVAC buttons. (I know there is for 8th and 9th gens, haven't heard about one for 7th.)
I would monitor the 2 powers and the ground at the harness on the back of the radio. If it doesn't lose any of those during an event, I'd assume the problem is inside the radio.
Disconnect power from it for a few minutes, as in a reboot. See if that helps. I'd probably try this first. Battery cables off and hold them together for a few minutes.
HTH
Old Oct 21, 2012
lowlife9's Avatar
i wouldn't disconnect the battery unless you know the security code for the radio because then you won't even have a radio. and there is a procedure to turn the AC off during defrost but i can't remember what it was i turned mine off years ago.here i found the diy
https://www.civicforums.com/forums/1...ogramming.html
Old Oct 21, 2012
Then he can post in one of the ungodly long "HELP I NEED MY RADIO CODE" threads that gets ignored!
This was one of the first things I did when I got my 12. I hate not having manual control over some things.
Old Oct 21, 2012
lowlife9's Avatar
especially in the dead of winter trying to get the ice off your windshield and the freakin AC turns on im sitting there freezing my ***** off. *** the defogger thats why i bought defogger spray for my window. but i do turn it on evey once in awhile to keep the AC lubed up.
4 banger
Jun 5, 2015 01:44 AM
mugenca
Apr 16, 2015 12:15 AM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
ACEM2
Dec 22, 2001 09:14 PM
