Front LED Turn Singal Problem
Old Aug 17, 2012
lawrencem2's Avatar
lawrencem2 is an unknown quantity at this point
Hey guys, I usually use the search function to get by but I'm having a problem I can't find the solution to. I have a 2002 civic that used to have a 68 LED 7443 (I did the 03 conversion) turn signal at the rear and an incandescent bulb at the front.
I replaced the incandescent bulb with a 24 LED 7443 turn signal. However, the lighting is now reversed when the headlights are on. The rear turn signal stays on while the front one is off. When the turn signal is activated, even my license plate lights start to blink! I tried switching the pins on one of the front bulbs using this link
http://store.ijdmtoy.com/1156-1157-3...ting-a/364.htm
but it did not help.
Any ideas on how to solve this? Do I need to switch the pins of all the bulbs?
chuffsy
May 15, 2015 12:50 PM
crowtoo
May 11, 2015 06:50 PM
civicns
May 8, 2015 09:49 PM
GH04si
Apr 15, 2015 08:13 PM
SWEETRIDE
Nov 27, 2001 05:52 PM
