2001 gauge cluster/fuses? Split personality-
Hello all,
We have a 2001 Civic with 45k miles on it.
The gauge cluster suddenly quits working- sometimes the entire cluster (all gauges) will go out and the brake light comes on.
We can turn off the engine, turn on and off the lights and restart the vehicle and the gauges (some of them- usually the speedo,tach, and temp) all come back on. The odometer usually doesn't work, or works least of the time.
The gas gauge isn't accurate except when above half, it shows when you add gas.
Also, the D flickers when the gauge is messed up.
We have done the diagnostic and the cluster checks out and we have looked at the fuses(both boxes) but I haven't pulled every fuse.
Thanks in advance-
Thanks in advance-
Re: 2001 gauge cluster/fuses? Split personality-
No clue if this is relevant or not, but it certainly might be: https://www.civicforums.com/forums/3...ake-light.html
Have to read this and look at the solder.
Thanks!
bsmiley
Aug 13, 2015 10:32 PM
BrandonD
Aug 9, 2015 10:22 AM
