05 Civic dead battery
Old Jun 14, 2012
coppafeeley's Avatar
coppafeeley is an unknown quantity at this point
hi all,
first post for me!
My 05 has been running great, just got home from work and 2 hours later wouldn't start. Just the tick tick of a dead battery. Boosted and fired right up so went for a drive to charge it up. When I turn on lights or other draw the radio will die out and warning lights come on for ABS and check engine etc, like when you have it in accessory position before starting.
Got it on charge now but i wonder if alternator isn't charging? Any other ideas?This is my first Civic!
Old Jun 14, 2012
Re: 05 Civic dead battery
Your alternator isn't charging. Figure out why.
Old Jun 14, 2012
mac25's Avatar
Dr Krieger of Modification
just drive it down to a lube shop and they can test your battery, alti and starter. it shouldn't be that pricey.
but if you jump it again and want to check the alternator your self hook a multimeter up to the battery.
first after charging it with a drive around turn the car off, the battery if it's good should read over 12v 12.5-14v. (off course this is just the voltage, your cca, cold crank amps could be shot).
then turn the car on. the volts should increase. then turn on the highbeams. if the volts drop down your alternator needs to be replaced.
I just did mine, a 2002 at 220 000km. so it is possible yours is at it's end.
Old Jun 14, 2012
lowlife9's Avatar
have it checked at autozone or similar establishment. check all grounds and wires.
Old Jul 10, 2012
dred's Avatar
dred is an unknown quantity at this point
when my alternator went I would measure 12 to 12.5v with car off
If I started it and measured the battery voltage was at 10V
My alt was killin my battery
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
twtron
Apr 17, 2015 12:09 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
