Installing radio on 03 civic
Old Feb 16, 2012
tonyd927's Avatar
tonyd927 is an unknown quantity at this point
Is there, if any, a way to install a new stereo without the removal of the entire interior of the vehicle?????
i drive a 2003 honda civic lx
Im trying to install a new radio but cant seem to pop out the unit using tools.
Can they make this any more difficult?
I drove a ford tauras and all i hadto do to remove the old unit was pry out the dash kit and then unscrew it.,
Old Feb 16, 2012
sl33pyriceboi's Avatar
Re: Installing radio on 03 civic
Your not suppose to remove the entire interior of your car.... Search for the DIY
Old Feb 16, 2012
tonyd927's Avatar
That would be called sarcasm. And I did and the only DIY vid or instructions instructed me to remove the entire center console ...which just sounds absurd. Is there another way?
Old Feb 16, 2012
CraigW's Avatar
https://www.civicforums.com/forums/a...4&d=1263508226
If the HVAC/Audio pod has never been out it is super tight (even tighter if the screws underneath are still in place) I had to reach in underneath and push out and grab edge with fingers and work it loose.
Old Feb 23, 2012
tonyd927's Avatar
bump...
so this is the only way??
Old Feb 24, 2012
CraigW's Avatar
Exactly what are you looking for ??
This is the procedure.
Old Mar 2, 2012
tonyd927's Avatar
gee, idk some easier way than removing the entire center console??
Old Mar 2, 2012
Brian1037's Avatar
Sedans > Coupes
Brian1037 is a jewel in the roughBrian1037 is a jewel in the roughBrian1037 is a jewel in the rough
There are two screws you need to get to that are only accessible after removing the center console. Don't be lazy, just go do it.
Old Mar 2, 2012
tonyd927's Avatar
lol. cheers mate.
Ok, the entire center console is out, most of the clips are broken, still cant figure out the wiring harness or how anything is supposed to be wired.
How do i get the cigarette lighter off?
how do i take out the stock radio?
how do i install the new radio using the dash kit?
what do i do if the car doesnt turn on after?
damn, i miss my ford.
Old Mar 2, 2012
rileyb22's Avatar
rileyb22 can only hope to improve
Originally Posted by tonyd927
lol. cheers mate.
-The wiring is going to be the same as any other radio install. If you've done it before, it should be no problem.
-You don't need to take the cigarette lighter off
-Unscrew the screws holding in the stock radio
-Read the dash kit instructions, or google it! it's not rocket science!
-If the car doesn't turn on after, youve done something terribly wrong
P.S. There is a DIY write up/vid on just about any type of radio install for just about any vehicle. GOOGLE IT!
Old Mar 2, 2012
rileyb22's Avatar
I typed in like 3 words and found this:
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=521&t ransactionid=1330731445-724977208&posted_by=rileyb22_www.civicforums.com&y outube_video_id=ME8UuEFWjmI[/autostream]
Old Mar 2, 2012
tonyd927's Avatar
THose are the exact directions I'm following. It got dark out before finishing so 3 broken clips, a cracked plastic panel and a missing option slot cover later i had to call it quits..
roverben
Jan 21, 2019 05:16 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
chgofirefighter
Apr 18, 2015 08:08 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
