Interior Instrument Light Replacement. DIY?
Old Jan 20, 2012
Corbdt's Avatar
Corbdt is an unknown quantity at this point
My 2004 EX Automatic has blown the interior light that illuminates the gear area, where the automatic shift **** is. Has anyone ever replaced this themselves, had this problem, etc..
Old Jan 20, 2012
Corbdt's Avatar
Re: Interior Instrument Light Replacement. DIY?
I am brandnew to this forum, and this is my first Civic, though I was a very satisfied Prelude owner in my high school and college days. 85, and 86Si.
Old Jan 20, 2012
CraigW's Avatar
You pull up the 2 trim covers around the shifter and the panel. The socket & bulb is on the drivers side, twist left to remove & right to install.
Bulb pulls straight out of socket.
Pick up a very common #74 bulb for the replacement.
https://www.civicforums.com/forums/a...4&d=1263508226
Old Jan 20, 2012
Corbdt's Avatar
Thanks for the help. So, in the attachment you included, would I just remove the shift trim ring and shift trim, and leave the console trim in place? And these pieces can by pry-ed up with just a flathead?
Old Jan 20, 2012
CraigW's Avatar
The trim ring comes 1st then the gear shift trim. You can leave the other in place iirc.
Use your fingers to remove those items. Release and pull them evenly or they could break.
HiImBrandon
Jun 1, 2015 07:34 AM
trellex
May 24, 2015 04:39 PM
One_PeeJay
May 17, 2015 05:31 PM
werdnahall
May 17, 2015 11:37 AM
supercivic01
South
Nov 30, 2001 11:27 AM
