Gauge and needles no light (blown?)
Old Jan 18, 2012
pole's Avatar
pole is an unknown quantity at this point
HI!
im from buenos aires, argentina.
i own a 2004 EX sedan
so today i decided to change the poor lightning of the climate controls and buttons with leds
i cant get the same lamps with led so i tried to install a led strip
but something went wrong, a shortcircuit produced, with some smoke and bad smell
and the rpm and speedometer rings had no light. the temperature and fuel ring light works fine. also the dimmer, the kilometers indicator, all the lights, the stereo etc
the needles are also dark, no light
so... any ideas? i will go to a honda service but here they took several days/weeks to work in your car
i´m very sad cause i tried to do an upgrade and i messed up another function
also the climate lights doesnt work anymore
thanks in advance
Old Jan 18, 2012
Re: Gauge and needles no light (blown?)
You could have burned out the dash light dimmer circuits with a dead short, All it takes is a LED connected backwards to be a dead short circuit.
I would start with removing everything you tried to install. Put it all back the way it was stock and original.
Then inspect ALL fuses in both fuseboxes.
Then take apart whatever let the smoke out. I'm going to guess it was in the gauge cluster. I would pull it out and look for burned spots in the electronics.
Then decide what to do with it.
Old Jan 22, 2012
pole's Avatar
thanks!
finally the fuses are all OK
but the cluster had a burned circuit and a pair of elements in bad condition. so a technician resolded them and replace the bad things
also all the bulbs of the climates control and buttons were burned
now all working fine
Old Jan 22, 2012
Good deal.
Probably far cheaper than replacing an entire gauge cluster.
Old Jan 31, 2012
pole's Avatar
here in my country: repair: 80usd, new cluster: usd 1808 (and theres no new clusters in honda dealers)
i will never touch nothing again
Ma213802
May 18, 2015 07:01 AM
werdnahall
May 17, 2015 11:37 AM
manicEL
Dec 10, 2001 06:33 PM
ShadyMilkMan
Nov 20, 2001 06:05 PM
meels808
Nov 15, 2001 07:16 AM
