Q&A period
Old Apr 30, 2002
mohawkboom's Avatar
Q&A period
I'm at work it's Dayum slow I'm bored.. post any general Car audio Q's you have or anything you can think of that may need clarification and I'll answer what I can.
Cheers
Me
Old Apr 30, 2002
Vizyun's Avatar
The Fallen Angel . . .
Vizyun is an unknown quantity at this point
Um. . .OK, here's one for ya. I've got the info on how to wire my 3 eclipses to the earthquake amp. Now, considering this will be the first system I put in myself, how do I wire it to the HU, power source, etc? I've never done an amp. Have put in an HU before, so have basic electrical and electronic knowledge. What gauge wire do you recommend? Where would be best to run it? What size fuse to use, and where to place it? What type of fuse? End connectors? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Apr 30, 2002
mohawkboom's Avatar
For that setup, I would reccomend 1/0 Guage wire, for pwoer and ground. Run that from your battery to a distro block that has 2 4 guage outputs. Run the power wire down the right side of your car. Run the RCA's and speaker wires down the left(drivers side) Fuse wise I'd say go for a 150amp breaker, or 150 amp ANL fuse with holder. Getting a good set of battery terminals will help with power transfer from the battery and allow you to upgrade your alternato to bat wiring to at least 4 guage as well. And same for grounds. I use Tsunami Lok-Nut terminals ..they have 2 1/0 Guage inputs and 2 8-gauge accessory inputs as well (great for neans. foglights...stuff like that)..
Old Apr 30, 2002
Crash2002's Avatar
Crash2002 is an unknown quantity at this point
what is the P. Cont wire for on the wire harness?
Old Apr 30, 2002
mohawkboom's Avatar
P.Cont.. umm Positive Continues aka +12 volt wire?.. what's the full title fer the wire [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 30, 2002
Crash2002's Avatar
i dont know thats all it says, would that be for the rem wire from the amp, because right now the amp only turns on when the Radio is on, not cd's
Old Apr 30, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
dude that's strange.
Old Apr 30, 2002
mohawkboom's Avatar
Yeah it is. could be a problem with your HU.. the remote turn on wire works with radio so it's connected..so when you play CD's it should work as well..hmmmm
Old Apr 30, 2002
Crash2002's Avatar
what if i connect it to the p. cont? because that doesnt go to anything
Old Apr 30, 2002
mohawkboom's Avatar
No CLue.. my HU has 3 wires goin in+ the antenna. the +12v, the Ignition turn on and dimmer wire. and the remote wire going out. so I haven't a friggen clue on that one..might wanna drop by a shop and haven em look at it..
Old Apr 30, 2002
Crash2002's Avatar
and i seem to be getting a whistling noise from my speakers now since i installed the new amp and front speakers, what could that be? bad rca's? i spent 50 bucks on the rca's so i dont think thats the problem, could it be my rca cables are too close to a power cable?
Old Apr 30, 2002
mohawkboom's Avatar
Where did yu ground the amp?.. do your RCA's at any point cross or come within 4" of your power or ground cable?..and what side of the car did you run the RCA's down?
Old Apr 30, 2002
Crash2002's Avatar
i didnt really have time to do everything right, I have a distrubution box under my passenger seat where my sub amp is and i ran the power from there to the left seat to the speaker amps, and the rca's are down the center console, yeah im pretty sure the Rca's are within 4 inches of the power and ground
Old Apr 30, 2002
mohawkboom's Avatar
sounds like the RCA's are just picking up noise from your power wires.. only way around it is to re run your wiring
Old Apr 30, 2002
Crash2002's Avatar
ok thanks, i think that covers all my questions, ill let you answer some other peoples questions if they have any
Old Apr 30, 2002
mohawkboom's Avatar
No probelm..tis what I'm here fer
Old Apr 30, 2002
edy's Avatar
edy
edy is an unknown quantity at this point
so, how much weight does all that sound deadening stuff add to your car?? (assuming you do doors, trunk, firewall, roof)
I bet I've at least added like 100 lbs. already!
Old Apr 30, 2002
mohawkboom's Avatar
well Brown Bread weighs .4lbs/square foot. I have 205 sq.feet. about 85lbs. I dunno the weight of raammat but it's gotta be close..if you have 120sq.ft figure about 50lbs.
Cheers
Mohawk
IronFist
Sep 25, 2015 07:13 PM
BigG422
Sep 9, 2015 10:59 PM
weedo
16
Oct 8, 2004 11:56 PM
SMP550
Mar 7, 2003 12:08 AM
kizak
Oct 13, 2002 12:54 PM
