Front left door speaker
Old Nov 16, 2011
Astarn's Avatar
Astarn is an unknown quantity at this point
My Front left speaker (in the door panel) isn't outputting any sound whatsoever ..the little speaker above it is (i think its a tweeter but i have no idea) Help please :P
Old Nov 16, 2011
lowlife9's Avatar
Re: Front left door speaker
im guessing the terminals got wet and corroded. take the speaker out and check it.
Old Nov 17, 2011
Astarn's Avatar
Not sure how to do that. Any videos or advice you can give? What would i be looking for on the speaker?
Old Nov 17, 2011
CraigW's Avatar
https://www.civicforums.com/forums/a...4&d=1263508226
Old Nov 18, 2011
cja3455's Avatar
cja3455 is an unknown quantity at this point
it should be an easy thing to do, all you need is a screwdriver. After you remove the speaker, make sure the speaker is the culprit not the wiring or something else. You need a multimeter for this to test the resistance between the two terminals, if the resistance reads anywhere between 4 to 8 ohms then your speaker is good, if the resistance reads infinity then your speaker has an open circuit and it is not good. Most probably it is the speaker but make sure before you buy a new one. I replaced my speaker few days ago, i bought the OEM one for 18 bucks from righthondaparts.com
39120-SDA-A02-Honda SPEAKER ASSY. (17CM) (SINGLE) (PIONEER)
Poopies
Apr 20, 2017 11:36 PM
GH04si
Apr 15, 2015 08:13 PM
supercivic01
South
Nov 30, 2001 11:27 AM
PimpBot5000
Nov 26, 2001 07:15 PM
doublins
Nov 11, 2001 07:01 PM
