radio and power locks not working
Old Jul 19, 2011
Lizking's Avatar
Lizking is an unknown quantity at this point
I just purchased a 2005 LX, and decided to replace the stock radio with one a bit fancier. I had little trouble getting the Radio/Climate Control console out, but when I plugged in the new stereo, it refused to power on. I pulled it out and put the stock radio back in, and that one refused to work as well. My first thought was that I had blown the radio fuse, but I pulled out the radio fuse and it didn't look blown.
I also noticed that the power locks would not work properly anymore. It used to be that if I hit the switch, it would lock all closed doors, no matter what. Now, it will only lock the doors if I have the engine running, or at least the car powered on. I also used to be able to lock all the doors by locking the driver's door with the key, but now that only locks the driver's door. I checked the fuse for the locks, and that one seems to be intact as well.
Old Jul 19, 2011
CraigW's Avatar
Re: radio and power locks not working
"back up" fuse under hood fuse box.
Old Jul 19, 2011
Lizking's Avatar
#9 "back up" is a 10 Amp fuse, right? There was a blown 7.5 Amp in #9.
And #3 is a 7.5 amp, right? there was a 10 amp in that one (not blown)
I just want to make sure my eyes aren't playing tricks on me before I power the car on.
Old Jul 19, 2011
sl33pyriceboi's Avatar
if u look at the cap of the box, it'll tell u how many amps each slot should be.
Old Jul 19, 2011
Lizking's Avatar
alright, thanks guys. I'd like to punch whoever did electrical work on this car in the nose. 7.5 amp fuses do not go in 10-amp slots
Old Jul 19, 2011
CraigW's Avatar
Smaller amperage is o.k. if it works still, larger amperage is not o.k.
Old Jul 19, 2011
rjones7755's Avatar
^Exactly fuses are designed to blow when a power spike hits them, keeping them from damaging your electronics so hypothetically if your radio could handle 7.5 amps and you put a 10 amp fuse in the slot, the fuse wont blow until 10 amps is exceed, allowing your radio to radio to receive too much power
roverben
Jan 21, 2019 05:16 PM
ORskier
May 3, 2015 12:54 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
darwin-t
Apr 18, 2015 09:29 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
