Haunted car
Old Jun 20, 2011
Bobthebuilder's Avatar
Bobthebuilder is an unknown quantity at this point
Angry Haunted car
So the wife was using our 03' civic as she dose, after turning the lights on the wipers started operating!!
So, after a few tests I found that using the windshield washer turns the side lights on & turning the sidelights on runs the washer motor full time with the wipers running.
Is there any link between these two systems???
Bob
Old Jun 21, 2011
MelJ's Avatar
Trance Addict
Re: Haunted car
Could have frayed wires crossing. When you turn one on, the exposed wires may be sending current through both circuits, causing both of them to activate. I don't have access to the wiring diagrams though.
Old Jun 21, 2011
lazlong's Avatar
Re: Haunted car
There's only one place those wires come near each other- in the wire bundle running down the steering column all the way to the under-dash fusebox. Take off the steering column covers (3 phillipshead screws on the bottom) and look for bad/burnt wires.
Old Jun 21, 2011
CraigW's Avatar
Re: Haunted car
"Is there any link between these two systems???"
Yes, the multiplex control unit located inside the under dash fuse box.
Old Jun 21, 2011
lazlong's Avatar
Re: Haunted car
Yes, but usually all the systems are affected.
To the OP: I still say the first place to look is in the steering column. The '01-'02s had a recall for this but, your '03 may not be immune either.
Old Jun 21, 2011
Re: Haunted car
Thanks for the pointers,, I'll take a look tomorrow if time allows.
Q. Dose the multiplex switch through a relay for the washer unit??
Old Jun 21, 2011
lazlong's Avatar
Re: Haunted car
The relay is built into the MCU.
Old Jun 22, 2011
CraigW's Avatar
Re: Haunted car
The 01-02 recall was for missing low beams. It involved a single pin/terminal at the headlight switch.
The 01-02s had some crazy symptoms solved by replacing multiplex units. Even items that did not appear in the list for micu control.
These items all are.
Old Jun 22, 2011
lazlong's Avatar
Re: Haunted car
Really? You learn new stuff all the time.
I was 900 miles from home when mine went. Big puff of smoke from the steering column right in the middle of the highway. Burnt the entire connector on top of the steering column. And that's a big connector. Luckily I was 1 mile from an independent Honda mech who hooked me up with the recall.
Old Jun 23, 2011
Re: Haunted car
So I pulled the steering column shroud off to find nothing that could be responsible. I presume that the panel above the accelerator pedal with the relays & fuses is the multi-plexer?? So I located the daylight relay and pulled it, so when I turn the lights on now as expected no day lights but no wiper/ washer operation either(this also eliminates the steering column). When I operate the window washer the day lights still come on so I presume the short is further down the line.
Next move is to pull the panel and look for some damage.
Q. Is there a separate relay for the washer, could't find one clicking there or under the hood.
Old Jun 23, 2011
lazlong's Avatar
Re: Haunted car
Originally Posted by Bobthebuilder
Q. Is there a separate relay for the washer, couldn't find one clicking there or under the hood.
"The relay is built into the MCU."
EDIT: You have a PM.
Old Jun 24, 2011
TDC2001civic's Avatar
TDC2001civic is an unknown quantity at this point
Re: Haunted car
is this the multi switch in the steering colum that fails like most cars, just curious
Old Jun 24, 2011
CraigW's Avatar
Re: Haunted car
The Multiplex Integrated Control Unit MICU handles many, many small electrical jobs and each generation it gets more tasks to take on.
On the Civic it is integrated into the under dash fuse box.
Some refer to it as the "body computer"
Old Jun 24, 2011
mysunsuion's Avatar
mysunsuion is an unknown quantity at this point
Re: Haunted car
I think CraigW make a very clear explanation on it..
___________________________________
http://www.used-rims-and-tires.com/
http://www.hondacivic2005.com/
Old Jun 25, 2011
Re: Haunted car
call ghostbusters?
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
