Headlight Buzzer
Headlight Buzzer
Does anyone know if 2002 Civic LX comes stock with a headlight buzzer? My 2005 EX does. So I do not if it is broke, missing, or non-existant on the 2002? Where does the buzzer plug in?
Re: Headlight Buzzer
Dome light works but not when door is open. It is a sedan and the two buttons on the front doors are broken. The buttons have broke off and are dangling inside the car frame. Since they are spring loaded, the car should 'think' the door is open all the time because the button is always in the open position.
The buttons on the rear door work properly.
my 2002 has a key and headlight buzz. im pretty sure almost every honda has it in the past 20 yrs. if yours is broken, replace the side door triggers otherwise the car will think the doors are always closed. it works opposite of how you think.
Not all Hondas come with the headlight chime. I had to add one to my 94. They were a dealer option for several years. There are several threads on a DIY headlight chime install.
***SOLVED***
Thanks for the replies gentlemen. Without reading your posts, I had a brainstorm. It is a sedan so I took the door light switches off the back doors and put them on the front. Presto, just like you said, that was my problem. I then superglued the front door light switches (making sure switch could still move) and put them on the back doors. All it fine now.
Thanks again for your replies. Making the world a better place... one Civic at a time.
Ok, noted...
___________________________________
http://www.used-rims-and-tires.com/
http://www.hondacivic2005.com/
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
