New System
Old May 16, 2011
JoshR709's Avatar
JoshR709 is an unknown quantity at this point
New System
Hey guys, i just received my new sound system today and pretty much have most of it installed but there are a few things i need to ask since this is my first time installing. I bought a Boss DVD flip out head unit and two 12" Kenwoods with a 1600 watt amp. I started by running my power wire down the side for the amp, then removed my console and factory head unit and ran my rca and remote wires down the center console. So i then started to wire up my new head unit with a new harness. Once i finished matching up my wires i was left with two that were not connected to anything (Illumination and Dimmer). What are these for and do i need to connect these to anything or can i just leave them capped off? Also I do not seem to have a remote turn on wire on my new deck for my amp, is there any other wire i can splice into? The car is a 2003 Civic Coupe LX.
Thanks alot,
Josh.
Old May 16, 2011
amamdani15's Avatar
amamdani15 will become famous soon enoughamamdani15 will become famous soon enough
Re: New System
DONT CONNECT EITHER OF THOSE. THEY ARE KNOWN FOR BLOWING OUT THE LIGHTS IN YOUR CLUSTER.
sorry to yell at you but im just trying to make a point...
EDIT: what boss dvd head unit is it (model number)? it should have a remote wire, its usually blue and has a stripe
Old May 16, 2011
rjones7755's Avatar
Re: New System
https://www.civicforums.com/forums/2...et-stereo.html
https://www.civicforums.com/forums/7...re-my-amp.html
Search is your best friend haha
Old May 17, 2011
JoshR709's Avatar
Re: New System
Its the Boss BV9974B and also where do i connect the parking break wire?
Josh.
Old May 17, 2011
amamdani15's Avatar
Re: New System
why dont you just bypass the parking brake wire?? if you can install the stereo yourself then im sure that you have enough intelligence not to watch a movie while driving. to bypass it you should just be able to connect it to anything that is ground and itll work. i looked at the manual for yours online and that is what it looks like.
Old May 25, 2011
clove's Avatar
clove is an unknown quantity at this point
Re: New System
Thanks, now i know why gauge cluster lights don't work..
coumadin01
Electronics
25
Jul 25, 2019 04:19 PM
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
