Need quick help with ECU fuse
Old May 14, 2004
ThsUserNmIsDumb's Avatar
Currently boosted at 0 psi.
ThsUserNmIsDumb is on a distinguished road
Exclamation Need quick help with ECU fuse
Okay, I read that one way to reset the ECU is to take out the ECU fuse. I've located it [blue, 15 amperes], but I can't take it out. Do i just yank with my fingers? also, should i disconnect the battery? is this even the best idea? thanks.
Old May 14, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
just diconect thr battery for about 2 min and reconnect. dont mess with fuses
Old May 14, 2004
Just pull it out. You can use pliars if your fingers are too big. Or just disconnect battery. It's the same. If you disconnect the battery, you lose all your saved radio settings, code, vafc stuff, etc.
Old May 14, 2004
Eh... I'll go fuse way. Thanks guys.
Old May 14, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
there are a little black pair of fuse pullers located in the fuse box...
use them
Don't disconnect battery
You'
l have to re-set your stereo!
Old May 25, 2011
lilo25's Avatar
lilo25 is an unknown quantity at this point
Re: Need quick help with ECU fuse
My '94 civic won't start, I checked the fuses and the ecu 15a was popped. replaced it and turned the key on... POP. that one went too. so i replaced it one more time with a 20a and that one lasted about 2 seconds longer and it eventually popped as well....any ideas?
Old May 25, 2011
DarkSouljur's Avatar
DarkSouljur has a spectacular aura aboutDarkSouljur has a spectacular aura about
I have an idea... make a new thread.
You brought back a thread from 2004 man, and it's not even in the right generation forum.
I dunno if this will help but about a week or two ago my car wouldn't start randomly... I towed it to my uncles garage and the whole ECU was defected so i had to get it replaced. Just thought i'd throw that out there as an option...
beveragemp
May 25, 2015 07:11 PM
twtron
Apr 17, 2015 12:09 AM
Jeff
Jan 4, 2002 12:27 PM
manicEL
Dec 10, 2001 06:33 PM
MooCoW
Nov 9, 2001 05:22 PM
