Amp Install
Old Feb 3, 2011
miketag89's Avatar
miketag89 is an unknown quantity at this point
Amp Install
What is the easiest way to run the power wire for my subs/amp? and how do you take apart the bottom side plastics on the floor by the door to run the wire?
-Mike
Old Feb 3, 2011
Re: Amp Install
there's a rubber grommet on the firewall, just to the right of the center console, under the carpet that you can use to run your power wire. As for the panels, they pop off, just gotta be careful with it.
this view is looking down into the engine bay, standing in front of the battery. The grey part at the top of the pic is my intake pipe.
and, for reference, the size of the wire I have going through that grommet, 13.61mm (~0.54 inches)
Old Feb 3, 2011
laser154380's Avatar
laser154380 is an unknown quantity at this point
Re: Amp Install
Just attach the power wire to a long screw driver or dowel and push it through the grommet. Then if you pop down your glove box you should see it, and then you can run it. Make sure if your running any RCA cables or speaker wires that you run them down the opposite side of the car so theres no interference. And if it makes any difference I have 4g wire through my grommet.
-chris
Old Mar 6, 2011
DanielSuzuki1's Avatar
Slow Ride
DanielSuzuki1 is an unknown quantity at this point
Re: Amp Install
I also ran my power wires through the grommet. I have a 4 gauge and an 8 gauge running through there. It was a major pain in the Azz. If the grommet pops out due to force applied, just push it back into place with your fingers until it is in position. mine went into the engine compartment, then into the passenger compartment before I got it right. Ground wherever it is convenient, but ground very very well. cheers!
Old Mar 6, 2011
K20Z3's Avatar
2010 Civic Si
K20Z3 is on a distinguished road
Re: Amp Install
This it the best option as opposed to actually drilling through the firewall. Its always better to use factory wiring holes for this kinda stuff.
Old Mar 6, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: Amp Install
Idk why you guys dont drill......
It's not as scary as it sounds, and it takes all but 15 seconds, and a bead of silicone to seal it
Old Mar 6, 2011
Slow Ride
Re: Amp Install
Typically I have in most of my other cars, just not much room under the hood in the Civic...
Old Mar 6, 2011
Kenny the Ricer
Re: Amp Install
Oh yeah, I forgot, I dont have a clutch....
I drill next to the steering column, typically where the clutch is, but I drive an auto
Old Mar 6, 2011
Slow Ride
Re: Amp Install
My last car was a maxima, and that's exactly what I did. My usual investigation this time told me it'd be a bad idea to drill, and I found said grommet. Tough to get my arm down there, but it looks clean! I pulled the 8 gauge for my front amp this morning, that one wasn't as bad as the 4 gauge. I am very glad to be done with pulling wires through this damn car though, I'll tell you that!
OptimisticWay
46
Oct 15, 2015 02:16 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
