factrory radio removal
Old Jan 17, 2011
brian02's Avatar
brian02 is an unknown quantity at this point
How do you remove the radio to get to the antenna wire. I want to install a FM modulator to play MP3 through the radio. Does any one have a walk through or diagram, pics of getting the factory radio out to get to antenna wire? 02 honda civic.
thanks
Old Jan 17, 2011
Re: factrory radio removal
Remove the center console (removing it helps access the bolts that hold down the radio.. assembly):
https://www.civicforums.com/forums/1...r-console.html
Remove head unit:
https://www.civicforums.com/forums/1...nda-civic.html
Old Jan 17, 2011
Brian1037's Avatar
Sedans > Coupes
Brian1037 is a jewel in the roughBrian1037 is a jewel in the roughBrian1037 is a jewel in the rough
yup you have to go through the center column to get under the head unit to undo 2 screws. i did it last summer. if you're anything like me, then you'll feel like it's not supposed to come apart but it is
Old Jan 17, 2011
J-K's Avatar
J-K
J-K is an unknown quantity at this point
Yeah, it's a struggle, but once you get it done it's worth it. Be careful not to break any tabs or anything, and make sure you have all the screws out before you start yanking on anything!
Old Jan 17, 2011
combinatorix's Avatar
combinatorix has a spectacular aura aboutcombinatorix has a spectacular aura aboutcombinatorix has a spectacular aura about
The first time is the toughest as you have to figure where to pry all the plastic junk apart, after that it's easy (provided you don't break anything)
Old Jan 20, 2011
brian02's Avatar
Ok , thanks for the pics, does not look to bad.
Dave1984
Jul 22, 2015 06:10 PM
jody501
Jul 10, 2015 11:01 AM
magog45
Jul 9, 2015 06:23 PM
ballmich
Jul 9, 2015 11:59 AM
