05 Civic Sedan Tweeter Questions
Old Dec 4, 2010
w1ldm4n's Avatar
w1ldm4n is an unknown quantity at this point
First, I'm sure this is a douple post of something somewhere, but after a couple of hours of Googling I still have some questions and clarifications needed.
I have a 2005 Honda Civic EX Sedan. It currently has an aftermarket head unit for my iPod, but all factory speakers. I would like to add new component speakers (probably the 6.5" Alpine Type-R components), but I am unsure what to do with the tweeters.
The sail panels (behind the side mirrors) seemed like a good place, but after popping off the panel, I found that there is a wire harness taking up most of the space back there. However, after looking around, I have seen numerous pictures of sail panels with tweeter mounting locations in them, as well as talk regarding factory tweeters.
Does my car (05 sedan EX) have factory tweeters in it somewhere that I haven't found, or are there stock tweeters in similar models?
Where can I find these sail panels in which I can mount tweeters, and how much do they cost? Also, would the Type-R tweeters (with a mounting diameter of 2") fit in them?
Is there a better place to put tweeters besides the sail panels?
Old Dec 4, 2010
Re: 05 Civic Sedan Tweeter Questions
you can put them in the sail panels by doing a surface mount on the front. that way you dont have space issues in the back. the coupes come with factory tweeters in that spot but the panels will not work on sedans. i had infinity tweeters mounted on the factory sedan sail panels. i still have em somewhere just took it off when i got rid of my speaker amp (theyre separate tweeters, not components, so i couldnt have them wired up anymore without the other 4 speakers running off the amp). some people put tweeters in the door panel too.
Old Dec 9, 2010
w1ldm4n's Avatar
Alright, I'll look at doing a surface mount I guess. Is there a way to angle them towards me though instead of pointing mostly sideways towards the passenger door?
Old Dec 9, 2010
it points at a good angle, not straight at your ears which can be annoying, but good enough that you hear them
Old Dec 14, 2010
w1ldm4n's Avatar
Alright, I'll probably just do that, the tweeters can angle some.
Also, can anyone help me with my other problem of running power to the trunk?
https://www.civicforums.com/forums/2...runk-help.html
Old Dec 18, 2010
whitecivic2003's Avatar
whitecivic2003 will become famous soon enough
this is what i did on my 03 sedan they sound good. i even took the time to hand paint them to match the deck
[IMG][/IMG]
Old Dec 18, 2010
MindBomber's Avatar
Live for the Twisties
^looks good, I like seeing everyone else's solutions to problems.
Old Dec 19, 2010
w1ldm4n's Avatar
whitecivic: are those the rear speakers? why would you put components in the back?
(i'm just leaving the factory rear speakers cause I can only afford speakers for the front.)
Old Dec 19, 2010
well bro i was an installer for years and i like my sound i have Jl audio 6.5" separates all the way around and a jl 300/4 to power them. I guess i am spoiled in your eyes but having clean sound is a must for me.
here is a pic of the front [IMG][/IMG]
Old Dec 20, 2010
Kennykid2002's Avatar
Kenny the Ricer
Very nice, another JL freak on board
I can't go anywhere near other brands except maybe hifonics(amps) and polks(for speakers only)
I currently removed my rear speakers though, planning to mount some 1" tweeters in the rear panel though
Old Dec 20, 2010
lowlife9's Avatar
i love me some german MB QUARTS or Diamond Audio i here the original manufacturer of mb quart is coming out with a new car audio line and i can't freaking wait to get my hands on them.
Old Dec 20, 2010
lowlife9's Avatar
here is the new company of the original mb quart manufacturers im so happy im a die-hard mb fan nothing comes close to them http://www.german-maestro.de/US/company.htm
Old Dec 20, 2010
yea i guess working for them for a few years makes me a bit bias to their product and currently working on the sub box for this to be powered by the 500/1 sitting and waiting
Old Dec 20, 2010
rockstock01's Avatar
rockstock01 is an unknown quantity at this point
Just throwing an idea out there for a slick tweeter mount. Why not use the windshield pillar mount? Those expensive guage pod things would make for a nice custom mount. If you had the time and loot to do it. I think it would look and sound pretty cool. You can probably order the same style guage pod for the right side in the JDM application.
Old Dec 21, 2010
Kenny the Ricer
People do that, and they even put 3~4 in speakers in bigger cars on pillar
Most likely those gauges will only fit 1" tweeters, but I dont really want them there since I already have them in my sail panel.
However, I have the coupe, and next to the rear seats are the side panels I do want to mount a tweeter in, I was even thinking of some 4"...but I think tweeters would be better.
Old Dec 21, 2010
The best location is always as close to the woofer as possible for sound quality and sound stage. Whichever method you choose, most manufacturers recommend that you mount your tweeters within 12" of the woofers. Otherwise, the high and low frequencies may reach your ears at different times, resulting in a sonic wave cancellation or "phase interference."
This is a great read check out this page
http://www.crutchfield.com/Learn/lea...oundstage.html
Old Dec 21, 2010
lowlife9's Avatar
well when the mids face outwards and way down on the door basically being covered by your legs i don't think it that big of a deal. i find the best place is around the door handle area.
Old Dec 21, 2010
w1ldm4n's Avatar
While that is true, isn't it more important that the distances between the listener and the woofer/tweeter be within 12" of each other? For example, I think it should be OK to have the woofer 3' away from the listener and the tweeters 3' in a slightly different direction.
Old Dec 25, 2010
w1ldm4n's Avatar
Alright, so I got the speakers today and opened them up and stuff, but it doesn't look like the type-rs come with a good way to surface mount. It seems that I have to go 3/4" down into whatever surface I'm mounting them to, and I don't know if there's enough space for that. Can I buy some sort of separate surface mount cups or something that I can use to install the tweeters?
Old Dec 27, 2010
usually they only come in the kit. i have my infinity reference tweets and panels lying around somewhere i can take pics of what it looks like when i find em. i will even sell them to you if you want.
Old Dec 29, 2010
w1ldm4n's Avatar
The Alpine Type-Rs that I got didn't have anything to surface mount them with, so I think I will have to drill a hole and do a flush mount. However, I keep seeing pictures of these all over the internet
and I found these part numbers also:
76221-S5P-A10ZA
76271-S5P-A10ZA
However, I have heard that they are only for the EX Coupes (I have a sedan), but I have heard from some people that you can fit them in the sedans. Can I please get a definitive answer from someone?
If that doesn't work, I was going to put them in the door panel like this
but there isn't a flat surface (my tweeters need a 2" hole and then go out more from there on the outside). Is that OK or will it pose a problem?
Old Dec 29, 2010
Kenny the Ricer
Coupe sail panels will not fit into the sedans.
If you had a coupe LX, GX, etc... the EX sails will fit.
You're better off putting them in the panel
Old Dec 31, 2010
electric130's Avatar
That's how I mounted my Infinity's
Old Jan 1, 2011
w1ldm4n's Avatar
Alright, I finally finished today.
Having no luck with the sail panels, I decided to just cut a hole and mount the tweeters in the door panel. Everything went smoothly and the curvature of the panel was not an issue.
Thanks for all of the help everyone.
Old Jan 1, 2011
wow it looks good!
Old Jan 1, 2011
Brian1037's Avatar
Sedans > Coupes
Brian1037 is a jewel in the roughBrian1037 is a jewel in the roughBrian1037 is a jewel in the rough
very nice! i'll probably do this when i switch out the speakers in my civic. on my last car (1998 corolla) i had a lot of problems with tweeters and the sails. ended up just screwing them in awkwardly.
Old Jan 1, 2011
looks great!
Old Jan 1, 2011
Kenny the Ricer
Looks like a clean install
Good work
Old Jan 2, 2011
how did you do the wiring, are they components?
vtec92
May 4, 2017 03:20 AM
hokiedad4
Apr 30, 2015 07:18 AM
dano2005
Apr 14, 2015 01:58 AM
aus10
Apr 13, 2015 09:26 PM
Crash2002
Oct 26, 2001 05:02 PM
